It is currently Fri Aug 01, 2025 1:24 pm
 Post subject: Steering wheel splines
PostPosted: Sat Jan 09, 2016 1:37 am
Can anyone tell me if the steering wheel splines are the same size on an Aus mini to a uk one ?
PostPosted: Sat Jan 09, 2016 5:52 am
Yes same up until UK went to airbags. I bought a Mountney wheel & hub in and it fitted fine. Sprite is same splines also.
The one I bought-
http://www.leacyclassics.com/featured-b ... sb007.html
Last edited by drmini in aust on Sat Jan 09, 2016 8:07 am, edited 3 times in total.
PostPosted: Sat Jan 09, 2016 6:25 am
Early sprite, midget is different
PostPosted: Sat Jan 09, 2016 10:16 am
Just be aware of the change in horn button location and the different column shroud.
PostPosted: Sat Jan 09, 2016 9:47 pm
Thanks, I bought a astrali wheel on fleabay this week and it is too small in the splines, if I mic the splines on my Aus min they are 19mm whereas the wheel boss is 17mm. My main worry is that it's my splines that are wrong (hence the question) I can now get back to him and ask for a refund.
Cheers Stan.
PostPosted: Sat Jan 09, 2016 10:20 pm
Early sprite is smaller in the spline diameter
PostPosted: Sat Jan 09, 2016 10:28 pm
Is there a specific spline size ? On the boss of the astrali there is 114/4a
Users browsing this forum: slacko and 83 guests
