https://ausmini.com/forums/
Modding gear stick position and length
https://ausmini.com/forums/viewtopic.php?f=2&t=91485
Author:  rapa59 [ Fri Jan 08, 2016 2:24 pm ]
Post subject:  Modding gear stick position and length
has anybody tried modding the gear stick? With the gearbox rebuild the shifter seems too much forward so I was thinking of putting a bend in it to bring it further back plus it's been chopped by previous owner so I may add some more height.
Anyone tried this and how'd you go?
Author:  timmy201 [ Fri Jan 08, 2016 2:33 pm ]
Post subject:  Re: Modding gear stick position and length
You could try one of the "Speedwell" type extensions, that would give you the height and might bring it back far enough?
http://www.minispares.com/product/Classic/BG8119.aspx
Author:  winabbey [ Fri Jan 08, 2016 2:46 pm ]
I seem to remember the Morris 1100 gear stick is slightly longer and has a rearward rake so can be used in place of the Mini types. morris 1100 on here would know so send him a PM if you want to know more.
Author:  timmy201 [ Fri Jan 08, 2016 3:07 pm ]
Morris 1100 stick looks like this
One came fitted in my car, but I wasn't a fan
Author:  Morris 1100 [ Fri Jan 08, 2016 4:18 pm ]
The black Mini K/Clubman/Mk2 S stick bends back further than the chrome Deluxe/Mk1 S type.
Author:  rapa59 [ Fri Jan 08, 2016 4:27 pm ]
Yes that Morris 1100 looks bent too much. Would anyone have a pic of the mk1 s type?
Author:  Curly [ Fri Jan 08, 2016 4:35 pm ]
I bent a Cooper S one back about another 5 degrees to suit the driving position in the Marcos. Do it cold - don't heat it up because you may damage the rubber bush, and don't bend it too far or it will interfere with the handbrake :oops:
