It is currently Sat Aug 02, 2025 6:02 pm
PostPosted: Sun Dec 20, 2015 3:16 pm
Milatsmadmini
My happy little 1152 is getting tired... On a hot day oil pressure after a while driving for a while will top out at 45psi at idle will sit at 10psi (1000rpm idle)
Is it time for a full rebuild? Or do I just re ring+ oil pump etc? What other things should be done while out?
PostPosted: Sun Dec 20, 2015 4:00 pm
Excessive bearing clearance is a main contributor to low oil pressure. Also , engines will wear the bores out in an oval shape so if there is excess piston slap a re-bore may be on the cards.
PostPosted: Sun Dec 20, 2015 4:07 pm
Matt, if you haven't done it before in the time you have owned, Rebuild, new Pistons/rings/bearings/cam reach head, and gearbox. That way it is NEW, and a known entity, so you know that it won't cause you any unnecessary grief. If you do it cheap, you will end up having to do it again later.
Aaron
Users browsing this forum: Steam and 85 guests
