It is currently Fri Aug 01, 2025 1:24 pm
 Post subject: Timing plate
PostPosted: Mon Jan 04, 2016 5:06 pm
I've got a couple of timing plates, the top one has the extra bracket on the corner. Is this used for anything important or can I just use the basic one?
 Post subject: Re: Timing plate
PostPosted: Mon Jan 04, 2016 5:28 pm
They are Morris 1100/1300 with the forward stabiliser onto their particular subframe mount. I'm not sure why the second one is slightly different again however (maybe auto??) You can use them but its not worth the extra loss of room out the front to get your hand in.
PostPosted: Mon Jan 04, 2016 5:41 pm
I trimmed mine with an angle grinder. Was an 1100S block originally but turned into a stroker.
PostPosted: Mon Jan 04, 2016 5:50 pm
Top one is 1100 or 1100S or maybe Minor/Sprite/Midget, it had 2 of those mount pads originally. One has been cut off so it fits in a Mini.
The bottom one is Mini.
PostPosted: Mon Jan 04, 2016 6:14 pm
ensure which ever one you use that you countersink the holes that the screws hold it to the block (if not there from factory).
PostPosted: Mon Jan 04, 2016 7:09 pm
That's the 2 screw holes at top of pics, holds the plate to the main bearing cap.
Users browsing this forum: slacko and 83 guests
