Electronic Fuel pump opinions https://ausmini.com/forums/viewtopic.php?f=2&t=91427 |
Page 1 of 2 |
Author: | bluewhitecoopers1968 [ Sun Jan 03, 2016 9:42 am ] |
Post subject: | Electronic Fuel pump opinions |
Hi all, Well my old su fuel pump has finally died. A new one is quite expensive. What are peoples opinions or experience with the facet pumps, such as the one I found on EBay? Cheers, Richard. http://pages.ebay.com/link/?nav=item.vi ... 18&alt=web |
Author: | Curly [ Sun Jan 03, 2016 10:35 am ] |
Post subject: | Re: Electronic Fuel pump opinions |
Excellent. Am using them on several cars and never had any problems. |
Author: | Davo111 [ Sun Jan 03, 2016 11:18 am ] |
what if I have a SPI, what should I use.:'( |
Author: | drmini in aust [ Sun Jan 03, 2016 11:18 am ] |
@ bwcs1968, I used them on both our cars, no problems. Cheap, and reliable. I mount them on a Mini centre exhaust mount (the big square rubber one) Bolts line up, just drill 1 hole 8.5mm in the vertical web and stick a 5/16 UNF Nyloc nut on it. |
Author: | peterb [ Sun Jan 03, 2016 2:29 pm ] |
Has anyone tried the points less system? |
Author: | Mick [ Sun Jan 03, 2016 5:12 pm ] |
peterb wrote: Has anyone tried the points less system? On the SU pumps? They go well too. |
Author: | bluewhitecoopers1968 [ Sun Jan 03, 2016 6:06 pm ] |
peterb wrote: Has anyone tried the points less system? Please explain? |
Author: | peterb [ Sun Jan 03, 2016 6:29 pm ] |
they make ones with out points, or you can buy kit to modify yours. http://sucarb.co.uk/electronic-pump-con ... -12-v.html |
Author: | bluewhitecoopers1968 [ Sun Jan 03, 2016 6:40 pm ] |
peterb wrote: they make ones with out points, or you can buy kit to modify yours. http://sucarb.co.uk/electronic-pump-con ... -12-v.html I think I'll go with the facet pump, I pulled my su apart and cleaned the points, put it all back in and it ran for 10 seconds and stopped again. Brrr. |
Author: | Morbo28 [ Sun Jan 03, 2016 8:22 pm ] |
The SUs can reportedly only handle 2.5 psi (a reliable source told me that with regards to my HIF44). Do the Facets (4-6 psi) drop pressure by the time they hit the front of the car, do people run regulators, or do the SUs just deal with it? Also - I'm assuming no one uses a return line with SUs? [I'm about to buy a Facet pump for the rear, with a fuel regulator in the engine bay to drop it to 2psi just before the carby. But open to recommendations] |
Author: | Morris 1100 [ Sun Jan 03, 2016 8:36 pm ] |
Facet pumps come with a range of different delivery pressures. Try to get the right one. |
Author: | Morbo28 [ Sun Jan 03, 2016 8:38 pm ] |
Ah okay - so is there a pressure drop across the length of the fuel line I should worry about or if I need max 2.5 psi at the carby, should I just get a 2.5 psi pump? |
Author: | drmini in aust [ Sun Jan 03, 2016 9:31 pm ] |
I think my square Facet pump is 3-4psi. It works fine with the Dellorto, and with the HS6 SU I had on before. I don't use a regulator, as cheap ones do more harm than good. Something else to fail. |
Author: | Morbo28 [ Sun Jan 03, 2016 10:07 pm ] |
Thanks for putting up with the thread hijack. FYI for future readers: with this advice added to previous research I ended up ordering the following Holley pump - not running a regulator. Holley website wrote: ![]() 25 GPH HOLLEY MIGHTY MITE ELECTRIC FUEL PUMP Street Carbureted Applications Compatible with all fuels and fuel additives PART# 12-426 FEATURESOVERVIEWSPECS 12 volt operation 1.5-4 psi operating pressure 25 gal/hr flow Good for up to 300HP naturally aspirated Reliable solid state design provides longer life Compatible with all fuels and fuel additives (gas, diesel, blended alcohol, e-85) Simple 2 wire hookup Self-priming and regulating 12” dry lift capable Quiet operation – 65db Great for carbureted trucks, cars, generators and agricultural equipment – also makes a great transfer pump Engineered and matched performance with Holley®, Demon®, Quick Fuel® and Edelbrock® carburetors(all trademarks are property of their respective owners. Edelbrock is a registered trademark of Edelbrock,LLC) Comes with fuel filter, fittings and mounting hardware Made in the USA TECH RESOURCESPARTS & KITS Should be mounted with in 12" of the fuel tank. http://documents.holley.com/199r10683rev2.pdf |
Author: | Alexw [ Sun Jan 03, 2016 10:48 pm ] |
Has anyone has experience with these carter pumps? ![]() I'm wary of facet pumps, heard a lot of bad things about them. |
