Rear camber-caster brackets https://ausmini.com/forums/viewtopic.php?f=2&t=91400 |
Author: | drmini in aust [ Wed Dec 30, 2015 8:18 am ] |
Post subject: | Re: Rear camber-caster brackets |
A friend fitted Minisport ones years ago and had problems, one broke. I moddecd mine as you have. . |
Author: | crisonic [ Wed Dec 30, 2015 10:49 am ] |
Don't waste your time . Go and buy KAD or MED ones . They are properly engineered Never had a problem |
Author: | Jonnoh [ Wed Dec 30, 2015 11:36 am ] |
I've bought minispares brackets. I didn't notice the holes were ovalised in the wrong direction; the bolts went through them so I was happy. They seem reasonably well made but perhaps a little fiddly in their adjustment. I don't know about 'wasting your time'. Minispares £35 vs £117 for KAD. Having said that if anybody has had problems with their minispares one then I'd be happy to change! KAD is kind of you get what you pay for.... Jon |
Author: | TK [ Wed Dec 30, 2015 1:57 pm ] |
I know of a KAD broken rear bracket. ![]() |
Author: | Aussie Brian [ Wed Dec 30, 2015 3:18 pm ] |
I have just fitted a set of the mini spares ones to a mates car and in doing so started thinking about whether these would ever need to be re-adjusted once you find the sweet spot? So I can see a lot of positives in altering originals so they are now permanently set. |
Author: | FNQ [ Wed Dec 30, 2015 4:40 pm ] |
in terms of fit, if the holes fit, then could the angle be a function of adjustment... ( ie each could actually still be correct ???) eg the original is set at .0 neg camber, the minispares at . 5 etc , and so the adjustability takes up the difference..... different roads all can lead to the same place????? just a thought... i am an advocate of beefier is better, after seeing the results of one collapse at a race meet |
Author: | Jonnoh [ Wed Dec 30, 2015 7:18 pm ] |
Yes I used a socket head screw for those two bolts (and washer etc), provided you have a long 1/2" adaptor. Jon. |
Author: | Phil 850 [ Wed Dec 30, 2015 8:17 pm ] |
Jonnoh wrote: Yes I used a socket head screw for those two bolts (and washer etc), provided you have a long 1/2" adaptor. Jon. That's good thinking Jon ![]() Perhaps Minispares should supply them in the kit ![]() |
Author: | Jonnoh [ Wed Dec 30, 2015 8:33 pm ] |
Yep, or maybe modify them so that the adjustment screw is 10-15mm further away from the corner of the bracket.... Does make you wonder how often they fit these themselves...! |
Author: | slide [ Thu Dec 31, 2015 9:30 am ] |
I just elongated the holes in the original brackets (as shown in one of Clive Trickey's books). |
