It is currently Sat Aug 02, 2025 8:02 am
 Post subject: What disc pads...
PostPosted: Wed Dec 30, 2015 8:22 am
...do people use with their 7.5" Cooper S brakes?
I'm currently using "green stuff" pads. When driving hard they just get better and better as they heat up. However, when cold it's a bit like "where are my brakes"?! I wouldn't want to emergency brake if I'd been cruising at 100 km/h for a while for example.
What are peoples experiences with the various pads available. I want to change over to ones that have excellent cold braking performance and reasonable hot performance rather than the other way around.
Thanks for your thoughts
Mikal
67 Deluxe
Dry suspension
4 synchro close ratio gbox
Cooper S brakes, no booster
 Post subject: Re: What disc pads...
PostPosted: Wed Dec 30, 2015 8:37 am
Go back to the EBC black stuff pads as they will give you a bigger bite.
Rob Forsyth
Miniot!!
PostPosted: Wed Dec 30, 2015 9:02 am
Rover Cooper
I thought you had to run a booster with a 1275 block, :'(
PostPosted: Wed Dec 30, 2015 9:07 am
Boosters only reduce pedal effort, don't actually improve braking efficiency. Many people prefer unboosted, I believe a lot of race cars are unboosted. Think this topic was discussed recently...
67 Deluxe
Dry suspension
PostPosted: Wed Dec 30, 2015 11:03 am
Yeah, for about 2 good stops! :evil:
I faded mine bad going down Kurrajong and also Mt Keira, could hardly stop at the bottom. Then took them off and went back to Greenstuffs.
Blacks are good for city driving, that's all, IMO.
Greenstuffs + a booster = excellent. :mrgreen:
PostPosted: Wed Dec 30, 2015 11:21 am
Hi Doc,
I find the first couple of braking applications with the greenstuffs are ordinary. Is that your experience?
When I was driving the Trans Flores Hwy in Indo last year, fast windy mountainous stuff, the greenstuffs were just awesome. As I said before, the hotter they got the better they got giving huge confidence in the car's stopping ability. I just don't find the same in "normal" driving..
67 Deluxe
Dry suspension
PostPosted: Wed Dec 30, 2015 11:36 am
I ran for years with greens and no booster yes the 1st 2 stops are a bit ordinary. Fine then.
I'm now 70 and getting soft, I like my servo!
PostPosted: Wed Dec 30, 2015 1:15 pm
Hi Doc, maybe I just need to stomp on the pedal a bit harder?
67 Deluxe
Dry suspension
PostPosted: Wed Dec 30, 2015 1:39 pm
Yeah. I used to drag the brakes a bit as I took off down the street. :)
