It is currently Wed Jul 30, 2025 9:53 pm
 Post subject: Developed a misfire
PostPosted: Sun Feb 14, 2016 6:23 pm
Online
My mini has recently developed a misfire on acceleration.
It seams to be getting slowly worse.
I pulled the plugs out and all were quite sooty except #4 which was dark tan on the electrode and insulator but sooty around the outside.
I've only been driving around the burbs so haven't been able to give it a real blast to heat it up significantly.
Plugs are BP5ES.
Any ideas :?:
 Post subject: Re: Developed a misfire
PostPosted: Sun Feb 14, 2016 7:37 pm
Try swapping the coil to see if that makes a difference as well as the usual points, condenser and plugs
PostPosted: Sun Feb 14, 2016 8:43 pm
Check all the wiring to the coil too, if you have a loose wire or spade connector it'll give a dodgy spark
PostPosted: Tue Feb 16, 2016 5:39 pm
Start with spark plugs. Then leads. One thing at a time or you will not know what is causing it. Have a look under the bonnet with engine running IN THE DARK to see if there are any stray sparks.
"Let us remove your "SHORTS"
PostPosted: Tue Feb 16, 2016 7:36 pm
Online
Checked the points for correct gap and OK.
Checked the plugs and they were a little big so I closed them up to 0.025" and then checked that all the leads/connections were tight.
Still had a miss.
Tonight I had a look in the dark and all was dark, as it should be :shock:
With nothing to loose I took it for another drive and the miss was still there.
With frustration :evil: I revved it out through the gears and it sort of felt a little better :|
So I repeated the above and eventually the cob webs were cleared and now runs great :D
Apparently it doesn't like being driven like Miss Daisy but more like, well 8)
Thanks for all the assistance
PHIL
Users browsing this forum: 1071 S, Majestic-12 [Bot], Phil 850 and 87 guests
