Useful Thread Taps https://ausmini.com/forums/viewtopic.php?f=2&t=91292 |
Author: | Morbo28 [ Tue Dec 15, 2015 3:07 pm ] |
Post subject: | Useful Thread Taps |
Hey all, What taps would you recommend are most useful for working on a Mini? I'm am getting a 5/16 UNF for the captive nuts to mount the rear subframe. What other threads would be useful? They would have to to be threads that are not easily replaced - eg block, gearbox, any captive nuts. (If there are nuts and bolts used I always use new ones). Also I figure 'intermediate' taps would be the way to go, or do you think I should consider 'taper' or 'bottom' taps? I figure I might as well combine postage and get a few more useful ones. I'm getting ~$10 'Sutton' ones by the way and a $15 tap wrench. Clearly not nearly top of the line but I'm aiming for something functional for cleaning out existing threads, not creating new ones so I figure they should do the trick. But opinions welcomed. |
Author: | drmini in aust [ Tue Dec 15, 2015 3:43 pm ] |
Post subject: | Re: Useful Thread Taps |
1/4 UNF, 5/16 UNF, 5/16 UNC (gearbox), 3/8 UNC (head studs), 7/16 UNF (main bearing bolts) |
Author: | DavidE [ Tue Dec 15, 2015 3:57 pm ] |
drmini in aust wrote: 1/4 UNF, 5/16 UNF, 5/16 UNC (gearbox), 3/8 UNC (head studs), 7/16 UNF (main bearing bolts) ...and a complementary set of dies whilst you are in buying mode? Cheers |
Author: | drjbeam [ Tue Dec 15, 2015 4:54 pm ] |
http://www.machineryhouse.com.au/T015 Looks like this set will do the lot on a mini Mini kingdom online might sell a set as well But I have to say there is nothing like the stuff that was made in the 60s around today I have my grandfathers box of tap and dies and the ones I brought about 8 years ago and they don't compare |
Author: | drmini in aust [ Tue Dec 15, 2015 5:35 pm ] |
drjbeam wrote: But I have to say there is nothing like the stuff that was made in the 60s around today I have my grandfathers box of tap and dies and the ones I brought about 8 years ago and they don't compare You can still buy good quality cutting tools here, they just cost more $$. For example, http://stores.ebay.com.au/Cutting-Tools ... 34.c0.m322 Or, try Blackwoods, Graham Mc Donald, or your local fastener shop. NOT bloody Bunnings etc... ![]() http://gmdengineering.com.au/ DavidE wrote: drmini in aust wrote: 1/4 UNF, 5/16 UNF, 5/16 UNC (gearbox), 3/8 UNC (head studs), 7/16 UNF (main bearing bolts) ...and a complementary set of dies whilst you are in buying mode? Cheers Yeah, add 3/8 UNF to the list (top of head studs). |
Author: | Skell1275 [ Tue Dec 15, 2015 5:46 pm ] |
Don't forget to get some cutting compound (eg rocol rtd) if you think it's bad removing a broken stud a broken tap is a real pain ☹️ , it will also help keep the taps sharp. |
Author: | Morbo28 [ Tue Dec 15, 2015 7:49 pm ] |
Thanks for the info guys - alrighty you've helped me make my choice. Thank doctor for the specific sizes, David yep I guess I should get the dies too, Mr beam thanks for the link and Skell I have a cutting lubricant I use for most drilling...eg this pool of oil and swarf lol ![]() But I'll check out that brand as I am due to buy more. I hate buying crappy tools. For the moment I'll get the cheapo 5/16 UNF for the subframe mount and an el cheapo 'tap wrench' as it's all I need for this build. Then I'll get a set of better quality taps and dies as I'll need them mostly for the second build I've got lined up. I'll look up some of the names you mentioned doctor. Cheers guys for all the help ![]() |
Author: | Mick [ Tue Dec 15, 2015 8:03 pm ] |
Personally, I would pick up the few sizes Doc has stated. You can get really good brand name parts (Sutton or P&N for example). Very little room in the toolbox, and you don't have all these useless sizes hanging around. Good quality brand name ones are where its at. Intermediate or finishing taps are what you will need. Not so much the long taper starter taps. |
Author: | Morbo28 [ Tue Dec 15, 2015 8:38 pm ] |
Okay so from judging by what you say it sounds like Sutton is a decentish brand, which is what I was looking at. I'll grab this first one and then grab the rest another time. I find it really strange that the tap wrench sells for over $60 when the tap is under $10 (both Sutton brands). And thanks for getting back to me about the tap type Mick - I'll grab the intermediate taps. |
Author: | drjbeam [ Tue Dec 15, 2015 9:22 pm ] |
That link gets advertised on classic restos by fletch I did a google search to find a set like mine and found that Id try repco or other places that offer lifetime warranty on tools if your only starting out |
Author: | snurkdog [ Wed Dec 16, 2015 3:05 pm ] |
you can buy good quality aussie made taps at bunnings,i reckon go with local product. give some aussie a job. |
Author: | drmini in aust [ Wed Dec 16, 2015 3:29 pm ] |
snurkdog wrote: you can buy good quality aussie made taps at bunnings,i reckon go with local product. give some aussie a job. How long since you went to Bunnings?? My local one sells absolutely NO taps now, nada, zilch. No decent high tensile bolts now either. And many of the drills they sell (Frost etc) are Chinese made now, Out in the sticks, Bunnings may be different... but they have lost me for ANY serious engineering hardware. |
Author: | pturnedge [ Wed Dec 16, 2015 5:57 pm ] |
drjbeam wrote: http://www.machineryhouse.com.au/T015 Looks like this set will do the lot on a mini Mini kingdom online might sell a set as well But I have to say there is nothing like the stuff that was made in the 60s around today I have my grandfathers box of tap and dies and the ones I brought about 8 years ago and they don't compare As a former sales employee for Hare and Forbes (and sheetmetal worker who also worked in mechanical assembly and a panel shop doing LOTS of rust repairs on Alfa's ![]() |
