It is currently Sat Aug 02, 2025 6:02 pm
 Post subject: Diff Ratios
PostPosted: Mon Nov 09, 2015 1:30 pm
hello im new to the mini club. i need help with some diff ratios? i have a 1972 clubman gt with the 1275 engine. when i do 100kph it revs at 4000rpm. i was thinking of going a higher ratio like a 2.95 or a 3.1 ? i do most is highway driving. any one with these ratios can u let me know what rpm your mini dose at 100kph? thanks
 Post subject: Re: Diff Ratios
PostPosted: Mon Nov 09, 2015 1:51 pm
Are you sure your speedo/tacho are reading correctly?
A 3.76 diff will give you 60mph at 4000rpm
A 3.44 is 60mph at 3650rpm
A 3.1 is 60mph at 3250rpm
A 2.95 is 60mph at 3100rpm
http://www.guess-works.com/Tech/ratio.htm
PostPosted: Mon Nov 09, 2015 2:34 pm
Have you checked your tacho against another rev meter like a timing light/dwell meter?
Have you checked your speedo against a GPS?
The tacho in my car was reading 300rpm high at 4000rpm and my speedo was off a bit, and my exhaust is very noisy.
I originally thought I had a 4.1 ratio because of the engine scream and high tacho reading.
PostPosted: Mon Nov 09, 2015 2:58 pm
taller gearing just wrecks accelleration tho
i wouldn`t bother going anything over a 3.4:1 ratio (which is probably what you have in there)
unless you have "PLENTY" more grunt than the usual.
PostPosted: Mon Nov 09, 2015 3:39 pm
That might be true but those of us that don't live in the Big Smoke - and so rarely indulge in Traffic Light GPs - really find our 3.1s (70+ @ 4000) quite useful...
Cheers, Ian
PostPosted: Mon Nov 09, 2015 7:47 pm
I have a 3.4 diff in my car
I have a smiths tacho ( never been checked against any thing else )
2200 rpm = 60 kph
3100 rpm = 80 kph
4000 rpm = 100 kpm
give or take 100 rpm
the speed readings are taken from my very old navman
Mark
PostPosted: Mon Nov 09, 2015 8:59 pm
I have a 3:1 in my 1275 mini and I love it. In lower power minis it'd be a bit slow going.
PostPosted: Mon Nov 09, 2015 9:03 pm
I run a 3.647 with 10" A008s.
110KMH on the TomTom = ~4700rpm on new Autogage tacho.
It sounds a bit busy, and as I have 1st gear traction problems a 3.44 is going back in it this Xmas.
PostPosted: Mon Nov 09, 2015 9:50 pm
Here is a chart that Phil 850 made up.
Phil 850 wrote:
I used the data for the 3.44 cooper diff in the Orange mini manual.
I then just calculated what the other ratios would come out at. It may not be perfect but should be very close.
PostPosted: Fri Dec 18, 2015 6:23 pm
hello thanks for the help. i had a 3;44 ratio, now i put in 3;1 a lot better for the highway.
PostPosted: Sat Dec 19, 2015 5:03 am
3.1 is a great ratio for highway use.
"Let us remove your "SHORTS"
Users browsing this forum: Steam and 85 guests
