It is currently Thu Jul 10, 2025 4:25 pm
 Post subject: Engine number
PostPosted: Wed Dec 09, 2015 1:44 pm
What would engine number 12YE/A/H**** be out of?
Thanks
 Post subject: Re: Engine number
PostPosted: Wed Dec 09, 2015 1:46 pm
1275 Automatic block. I have one in my car converted to manual. Found in Morris 1300's and others
PostPosted: Wed Dec 09, 2015 2:01 pm
Running the same block here.
Needs oil way mods and an oil pump spacer to use in a manual.
I can do that here if you need it.
PostPosted: Wed Dec 09, 2015 3:11 pm
gtogreen1969 wrote:
Found in Morris 1300 Automatic only.
Fixed. 8)
PostPosted: Wed Dec 09, 2015 3:22 pm
Fixed. 8)
OK what were in the Morris 1100S automatics?
I had a 12H/169/H, (early one I suspect), what others?
edit I checked the number again it was 169 not 119.
Last edited by drmini in aust on Wed Dec 09, 2015 3:59 pm, edited 1 time in total.
PostPosted: Wed Dec 09, 2015 3:44 pm
I have seen the 12YEAH listed against an 1100S. I will see if I can find the website again.
There is also this one 12YAAH???
PostPosted: Wed Dec 09, 2015 3:45 pm
This page is from Peter Davis' recently published book.
ADO16 is Morris 1100 and 1100S
YDO9 is Morris Nomad
YDO15 is Morris 1300 and 1500
YDO30 is Californian Moke - Export
Page removed, hopefully temporarily.
PostPosted: Wed Dec 09, 2015 3:53 pm
gtogreen1969 wrote:
Found in Morris 1300 and Nomad.
Fixed. 8)
Double fixed :lol:
PostPosted: Wed Dec 09, 2015 4:01 pm
They changed the prefix when they changed models.
The 1100S started with a fully imported 12H/169/H before moving to the locally assembled 12YA/A/H.
The 1300 Automatic (and Nomad) came with the 12YE/A/H.
The only real difference between the two would have been the change from a generator to an alternator.
PostPosted: Wed Dec 09, 2015 5:46 pm
Isn't there a copyright on that info Doug or do you have permission from the book writers
I paid a $100 for that book to get that info and I think others should do the same and not just put up freely on a forum I know some time went onto getting that book finished that's why I didn't mind paying for it
I know there was some pdf samples on there site but still I think only after there's no copys of the book left and a period of time after that then it should be used
If the stuff you have was provided to write up the book then fair enough use it as you will
PostPosted: Wed Dec 09, 2015 6:01 pm
I'm pretty sure Peter said it was OK to show a few pages that answered specific questions, but I've removed the pages while I check with him.
PostPosted: Wed Dec 09, 2015 6:03 pm
A few pages here and there may be good advertising for his book.
PostPosted: Wed Dec 09, 2015 6:50 pm
There was good advertising on here before it was put out to the public gto
I just noticed your name on the second page of the book Doug but id still be asking for permission from the publisher or authors first as your stuff becomes there stuff In the weird world of today
Also gto i put up a link that come off the moke forum on here for a Haynes mini manual with missing chapters which is easily found on the net on here when I just started with minis and not Long after joining the forum as there wasn't a manual on here at the time. the link was pulled off the forum 30 min later by a mod saying to do with copyright and was told I can pm the link to members on here. I was pming the link for weeks
Don't ask me for the site as I don't know it no more either go look for it on the moke forum it was there if any one is interested in it
PostPosted: Wed Dec 09, 2015 7:42 pm
I was one of many who contributed information for the book. Since publication I've provided Peter with corrections and suggested changes, most of which have been adopted I understand. A reprint is on the way as all first editions have been sold.
I've mentioned to him the possibility of marque specific versions, such as a Mini and Moke document with only the data from the book that applies to those cars. I think Mini enthusiasts would be more likely to buy a condensed version rather than the full 290 page book.
I've emailed Peter re our current discussion. Will let you all know after we chat.
PostPosted: Wed Dec 09, 2015 8:04 pm
Thanks guys
so 1275 from a Morris 1300 it is
How long will the motor last if the oil way mods and the oil pump spacer were not done?
