It is currently Sun Aug 03, 2025 1:05 am
PostPosted: Sun Dec 06, 2015 3:15 pm
Re - Overfueling at high rpm's
Chasing an over fuelling issue with a 1275 with 100hp using a 2.25 needle valve in a 45DCOE. I have read text on the subject and it says a 1.75 /2.0 needle and seat would be the one to use.
Would running the slightly larger 2.25 needle valve cause an over rich condition / high float level?
I understand the theory behind it - Just don't know at what size difference would cause this overfueling pulsing to occur.
Just after some thoughts before I order a smaller needle valve.
Cheers Brad
PostPosted: Sun Dec 06, 2015 5:41 pm
No, the bigger needle & seat will merely allow more fuel flow on a bigger motor.
That said,it is pretty big- I run a 1.75 on the 1360's 45 Dellorto.
PostPosted: Sun Dec 06, 2015 6:02 pm
Hi Doc
I have a read a few things now for the pulsing rich mix theory. I will order a 1.75 Monday and see what happens.
Page 64 of Des Hammills book talks about it but doesn't say how much larger will cause the richness. http://foxed.ca/rx7manual/manuals/carb_book.pdf
Users browsing this forum: No registered users and 68 guests
