It is currently Sun Aug 03, 2025 1:21 am
PostPosted: Sat Dec 05, 2015 2:49 pm
How do people go about repairing the upper arm - the wear under the ball and cup when the cup wears through?
Would a little bit of Araldite work?
PostPosted: Sat Dec 05, 2015 2:55 pm
Yes, make sure the drain hole is clear, mix a bit up and push the socket in. Excess will come out the hole.
PostPosted: Mon Dec 07, 2015 11:35 am
devcon works too
but grease the bottom of the nylon cup so it don`t stick
& can be removed easilly
