https://ausmini.com/forums/
Carb Spacer Required?
https://ausmini.com/forums/viewtopic.php?f=2&t=91152
Author:  Thorlek [ Tue Dec 01, 2015 10:49 am ]
Post subject:  Carb Spacer Required?
Hey All,
Do you need to use a spacer between the manifold and the carby? (HS4)
What is the purpose of them anyway?
Thanks!
Author:  timmy201 [ Tue Dec 01, 2015 11:21 am ]
Post subject:  Re: Carb Spacer Required?
I think the throttle cable brackets are designed to use them and might be at slightly the wrong angle without them? I think I have a spare alloy one if you are interested?
Author:  Thorlek [ Tue Dec 01, 2015 3:59 pm ]
Righto, I guess I just need to do a test fit and see what happens.
The only other issue I can see is the un-threaded section of the stud on the manifold might be too big without a spacer to take up some of the room.
Thanks for the offer timmy, i'll let you know if I need it.
