It is currently Sun Aug 03, 2025 12:15 pm
PostPosted: Sat Nov 28, 2015 6:36 pm
Just wondering what is an acceptable amount of slop/free play at the gear stick on a remote gearchange
And what are the common parts that wear out
1970 MK2 Cooper S
PostPosted: Sat Nov 28, 2015 9:04 pm
there are bushes through the assembly that can be replaced - I replaced the bushes for the vertical shaft in the diff housing and it made a huge difference
PostPosted: Sat Nov 28, 2015 10:59 pm
There are also ball and socket joints in 4 places on a remote shift box.
The balls wear oval or get flats on them. When bad, I have had success building them up with 2.5mm Toolcraft electrode, then sanding back to shape on a linisher belt.
In the remote, there is a split nylon ring on top of the shifter's big ball, and a nylon socket on the bottom ball. Replace both if worn, apply grease on assembly.
