https://ausmini.com/forums/
Cooper S Gearbox Remote Change
https://ausmini.com/forums/viewtopic.php?f=2&t=91131
Author:  GundyGuy [ Sat Nov 28, 2015 6:36 pm ]
Post subject:  Cooper S Gearbox Remote Change
Just wondering what is an acceptable amount of slop/free play at the gear stick on a remote gearchange
And what are the common parts that wear out
Author:  simon k [ Sat Nov 28, 2015 9:04 pm ]
Post subject:  Re: Cooper S Gearbox Remote Change
there are bushes through the assembly that can be replaced - I replaced the bushes for the vertical shaft in the diff housing and it made a huge difference
Author:  drmini in aust [ Sat Nov 28, 2015 10:59 pm ]
There are also ball and socket joints in 4 places on a remote shift box.
The balls wear oval or get flats on them. When bad, I have had success building them up with 2.5mm Toolcraft electrode, then sanding back to shape on a linisher belt.
In the remote, there is a split nylon ring on top of the shifter's big ball, and a nylon socket on the bottom ball. Replace both if worn, apply grease on assembly.
