It is currently Sun Aug 03, 2025 1:04 am
 Post subject: Alloy Radiator
PostPosted: Tue Dec 01, 2015 12:03 pm
Looks like I need a new radiator and was looking at the alloy ones, does anyone have good or bad thoughts on these, I would really like to find out if they are as good as they say and if they fit and who is the best place to purchase
 Post subject: Re: Alloy Radiator
PostPosted: Tue Dec 01, 2015 3:28 pm
I wouldn't use anything else.
PostPosted: Tue Dec 01, 2015 3:56 pm
Quite a few people use them, I think the only real issue is it can sometimes be a little fiddly to fit the shroud onto them.
but I think that problem differs from unit to unit, as there are a few different ones available
1975 Hairy Lime/White Clubby
PostPosted: Tue Dec 01, 2015 4:01 pm
I went from a 2 core copper to a 2 core alloy (normal thickness alloy)
The alloy one ran hotter so i put the 2 core copper back in.
http://www.flickr.com/by_dan
2014 Land Rover Defender 90
PostPosted: Tue Dec 01, 2015 4:27 pm
The 2 core copper ones are OK for slightly modded engines as I have one in my 1100 van. I think it originated from mini spares UK, and I purchased from Karcraft in Sydney. I have a mini spares alloy one in my Supercharged mini and it rarely reaches 1/2 on the temp gauge. And I know the gauge works as the temp went to red when the thermostat stuck :(
1969 Cooper "S"
1967 Mini Deluxe
2019 MINI F55 Cooper S
PostPosted: Tue Dec 01, 2015 4:39 pm
got one in 73 van no problems will be changing the other cars over in due course happy with them :)
65 panel van Sprog
73 panel van Iggy
PostPosted: Tue Dec 01, 2015 5:51 pm
I put one of the 50mm Chinese alloy radiators in. This is its 4th summer and never had an issue. Engine sits on 80 to 85 degrees and even on a hot 40 degrees Canberra day, sitting in traffic, the temp gauge won't move. Mine also has a recovery cap on the radiator so I run an expansion tank.
1963 Morris 850
PostPosted: Wed Dec 02, 2015 7:33 am
Be careful mounting the alloy radiators. They take 6mm screws to hold the shroud on, and they MUST be short ones. If too long, you will punch holes in the core.
Some rads come with correct short screws, some with none. So, watch it. :)
PostPosted: Thu Dec 03, 2015 5:47 pm
Die Die Die!!
i fitted one to my daihatsu moke, and never had an issue with it, just one of the yum cha cheap ones from ebay
PostPosted: Fri Dec 04, 2015 2:27 pm
There is nothing wrong with Alloy radiators. Have not come across a bad one yet. Easier to fit than the original type and cool quicker and better. If not so there is an underlying problem with the engine.
"Let us remove your "SHORTS"
Users browsing this forum: No registered users and 69 guests
