Morris 850 to 1100 conversion https://ausmini.com/forums/viewtopic.php?f=2&t=91103 |
Author: | Skewy33 [ Mon Nov 23, 2015 11:02 pm ] |
Post subject: | Morris 850 to 1100 conversion |
Hi guys, Recently brought a 62 morris 850 that came with 2 1100 engines one complete other missing the head, im looking at installing it into my 850, just wondering if its a simple swap or more difficult the complete engine has a later model box on it but the incomplete engine has the older stle which will suit my mini would it be as simple as bolting the older gear box to the other engine and straight in? Here some pics of them |
Author: | simon k [ Wed Nov 25, 2015 6:59 pm ] |
Post subject: | Re: Morris 850 to 1100 conversion |
basically a straight swap |
Author: | 1071 S [ Wed Nov 25, 2015 7:41 pm ] |
OK theoretically like Simon says.... However.... The box attached to the headless engine is an original 850... which means its at least 51 years old. Maybe ... hopefully... its been rebuilt - but one would need to check. If your current 850 box works (at least you what sort of health its in) it may be a better bet than the unknown other.. The other box looks like a much later 4 synchro "poverty pack" unit. Can't see that clearly in the photo but it looks like one.... These have a much dodgier shift mechanism (some of which is missing) but is a much newer design and has maybe done less miles. Same deal though ..you need to check the condition before going too far.... So, yes, the swap is easier ..but you need to make sure its worth it first .. Cheers, Ian |
Author: | DavidE [ Thu Nov 26, 2015 5:26 am ] |
1071 S wrote: OK theoretically like Simon says.... However.... The box attached to the headless engine is an original 850... which means its at least 51 years old. Maybe ... hopefully... its been rebuilt - but one would need to check. If your current 850 box works (at least you what sort of health its in) it may be a better bet than the unknown other.. The other box looks like a much later 4 synchro "poverty pack" unit. Can't see that clearly in the photo but it looks like one.... These have a much dodgier shift mechanism (some of which is missing) but is a much newer design and has maybe done less miles. Same deal though ..you need to check the condition before going too far.... So, yes, the swap is easier ..but you need to make sure its worth it first .. Cheers, Ian That's a quaint turn of phrase to describe the 4 syncro box with remote change, Ian. I'd take my remotes any day over the alternative. |
Author: | drmini in aust [ Thu Nov 26, 2015 5:47 am ] |
DavidE wrote: That's a quaint turn of phrase to describe the 4 syncro box with remote change, Ian. I'd take my remotes any day over the alternative. Is it the infamous `puddin' stirrer' direct shift, used on pov pack cars from 1969 to 1973? with the remote 22G1128 box? These were a great box but the puddin' stirrer shift wore bad and there's no adjustment. I rebuilt one for a Moke recently. pic of the setup- ![]() |
Author: | sitnlo62 [ Thu Nov 26, 2015 7:26 am ] |
This Gearbox Diff housing is badly Broken so you probably won't be using that. That Power Unit is out of a morris 1100 anyway!! Don't know why it is percieved to be a 4speed full syncro 22G1128 Its just a 3 syncro morris 1100 box, have a close look at the remote housing mounting point (rubber sandwich type) clearly visible, as is the morris 1100 front engine plate, if you enlarge the photo. |
