Any Idea what year this Deluxe is? https://ausmini.com/forums/viewtopic.php?f=2&t=91076 |
Author: | Jenk [ Sat Nov 21, 2015 5:29 pm ] |
Post subject: | Any Idea what year this Deluxe is? |
Can anyone work out what year this Deluxe might be? its just a bare shell so no wiper motor to go by. Type: YMA262 Body number: 26550 Number on radiator shroud: 26062 Engine number 9YA/Ta/H 27490 Paint code is 1/BURGUNDYRED/3 ..... also what does the preceding 1 and the following 3 represent? |
Author: | DavidE [ Sat Nov 21, 2015 5:40 pm ] |
Post subject: | Re: Any Idea what year this Deluxe is? |
Jenk wrote: Can anyone work out what year this Deluxe might be? its just a bare shell so no wiper motor to go by. Type: YMA262 Body number: 26550 Number on radiator shroud: 26062 Engine number 9YA/Ta/H 27490 Paint code is 1/BURGUNDYRED/3 ..... also what does the preceding 1 and the following 3 represent? 1967 1/ means enamel paint /3 means Berger paint Cheers |
Author: | Jenk [ Sat Nov 21, 2015 5:48 pm ] |
Thanks David... care to elaborate on how you came to it being a 67? |
Author: | DavidE [ Sat Nov 21, 2015 5:51 pm ] |
Jenk wrote: Thanks David... care to elaborate on how you came to it being a 67? Because I own 27568 and 33015. The latter is May 1968. The former is second half of '67. |
Author: | gtogreen1969 [ Sat Nov 21, 2015 5:51 pm ] |
This is a couple of thousand before yours. 1967 morris mini deluxe Chassis no--Yma2s2/24431 Engine no--9ya/ta/h 25411 Date purchased--31.10.67 |
Author: | Jenk [ Sat Nov 21, 2015 5:58 pm ] |
Thanks again David... makes sense when you provide those facts. GtOgreen based on your info wouldn't that make mine more likely closer to a 68? not that it matters too much. Thanks guys |
Author: | Morris 1100 [ Sat Nov 21, 2015 6:02 pm ] |
The nearest one I have... Chassis no-YMA2S2/25776 Engine no-9YA/Ta/H 26769 Date purchased-20.6.67 |
Author: | gtogreen1969 [ Sat Nov 21, 2015 6:04 pm ] |
Bit of info here. viewtopic.php?t=74269 Mini De Luxe register? |
Author: | gtogreen1969 [ Sat Nov 21, 2015 6:08 pm ] |
Jenk wrote: GtOgreen based on your info wouldn't that make mine more likely closer to a 68? not that it matters too much. Thanks guys If you have a spare weekend. Try searching the forum and make up a list. Then take the average. |
Author: | Jenk [ Sat Nov 21, 2015 6:23 pm ] |
gtogreen1969 wrote: Jenk wrote: GtOgreen based on your info wouldn't that make mine more likely closer to a 68? not that it matters too much. Thanks guys If you have a spare weekend. Try searching the forum and make up a list. Then take the average. All good mate thanks for the info and thanks for your help. |
Author: | gtogreen1969 [ Sat Nov 21, 2015 6:26 pm ] |
I wouldn't be to worried even if there was a 4 or 5 month difference between passports to service of similar numbers. The early date may have been preordered and the later one might have been the demo model - or beige ![]() |
Author: | John Sneddon [ Sat Nov 21, 2015 7:08 pm ] |
YMA2S2 26550 would be June 1967 |
Author: | Jenk [ Sat Nov 21, 2015 7:29 pm ] |
Awesome...thanks John |
