clubman heater https://ausmini.com/forums/viewtopic.php?f=2&t=91070 |
Author: | BL-235-MC [ Sat Nov 21, 2015 12:46 am ] |
Post subject: | clubman heater |
hello, i search always to transform my european clubman to aussie clubman. i have buy to ebay a heater. but i search information, pics to put this, if is possible parts for find this. i don't have switchs and low dash board. thanks |
Author: | BL-235-MC [ Sat Nov 21, 2015 5:40 am ] |
Post subject: | Re: clubman heater |
one question : is possible to have left driver with this ? |
Author: | BL-235-MC [ Tue Dec 01, 2015 9:25 pm ] |
up |
Author: | shnitzee [ Tue Dec 01, 2015 9:42 pm ] |
Hi Arnaud Ive got two spare heaters so I might have the plastic elbow piece you are looking for. I will have a look in the morning. Cheers Eiles |
Author: | BL-235-MC [ Wed Dec 02, 2015 9:55 pm ] |
shnitzee wrote: Hi Arnaud Ive got two spare heaters so I might have the plastic elbow piece you are looking for. I will have a look in the morning. Cheers Eiles ok thank. the heater have one or two elbow ? |
Author: | shnitzee [ Thu Dec 03, 2015 9:03 pm ] |
It has two elbows. I've got a couple in good condition you can have for free. PM me your address and I can send them to you. I'm not sure what the postage will be though; shouldn't be all that much as they are quite light. Cheers Eiles |
Author: | BL-235-MC [ Fri Dec 04, 2015 10:01 pm ] |
PM in your box. |
Author: | shnitzee [ Fri Dec 04, 2015 11:13 pm ] |
Cheers. I'll pack them up and send them off tomorrow. Good luck with the rebuild. Eiles |
Author: | BL-235-MC [ Mon Dec 07, 2015 5:56 pm ] |
shnitzee wrote: Cheers. I'll pack them up and send them off tomorrow. Good luck with the rebuild. Eiles thanks, i have payed with paypal. |
Author: | John Smidt [ Mon Dec 07, 2015 6:36 pm ] |
[quote="one question : is possible to have left driver with this ?[/quote] You can convert to left hand drive fairly easily, You will need a left hand drive steering rack and you may have to re route some of you brake pipes, and heater hoses, but as far as I can remember all the rest should be able to be changed from Right hand side ( The correct side to drive from ) over to the left hand side ( the wrong side ) Good luck with your resto |
Author: | shnitzee [ Tue Dec 08, 2015 12:22 am ] |
Thanks Arnaud |
Author: | BL-235-MC [ Tue Dec 08, 2015 5:16 pm ] |
John Smidt wrote: BLMC wrote: one question : is possible to have left driver with this ? You can convert to left hand drive fairly easily, You will need a left hand drive steering rack and you may have to re route some of you brake pipes, and heater hoses, but as far as I can remember all the rest should be able to be changed from Right hand side ( The correct side to drive from ) over to the left hand side ( the wrong side ) Good luck with your resto yes, is not a problem of parts. I think it will move the heating block to the right, otherwise the pedal to accelerator and my feet will kick it. |
