It is currently Sat Aug 16, 2025 8:27 am
Post new topic Reply to topic  [ 29 posts ]  Go to page 1, 2  Next
PostPosted: Fri Jul 11, 2008 7:06 pm
I am planning to have some front heal mats made for a Mk2 Cooper S / Clubman GT.
They should be excellent reproductions with the mould being made from an original Mk2 S Mat.
Any one interested in purchasing one to help reduce the costs?
(The mould alone will cost about $1,500)
Cost will be between $80 and $100 each, depending on the interest. Even less if sales are high.
The original mat measures 183mm X 303 mm, and has 27 X 46 squares.
When they copy the mat to make the mould, any wear will be removed, and the rubber compound used will be very similar to the original.
Lead time will be about 6 weeks from when I give the go ahead.
PM me with details if you are interested,
The photos are of the original to be used.
PostPosted: Fri Jul 11, 2008 7:47 pm
Hey im in.
Im sure many people on the GT forum will be keen as well. I put a post on there for you
Im sure the mini places will be interested in purchasing some from you as well. Ie mini king mini spares etc. So check them out as well
Cheers Brenton
PostPosted: Sat Jul 19, 2008 10:12 am
Any other interest in reproduction heal mats for the Mk2 Cooper S, Clubman GT?
They should come up like new original ones.
I need about another 10 to make it worth getting done.
PM me if you are interested.
PostPosted: Sat Jul 19, 2008 10:35 am
Minisport in South Aus sell them ... You get the heel and toe mat for $79 ..
http://www.minisport.com.au/category46_1.htm
EDIT : They are an excellent reproduction of the original .... heres a pic below of the original carpet out of my Mk1 Cooper S
1965 Morris 850
1966 Morris Mini Minor
1967 Morris Cooper 'S'
1977 Leyland LS
PostPosted: Sat Jul 19, 2008 10:56 am
They are different patterns.
PostPosted: Sat Jul 19, 2008 11:26 am
that one that minisport sell is the mk1 heel mat NOT the mk 2 mat.
PostPosted: Sun Jul 20, 2008 7:58 pm
Ok thanks ...I stand corrected , thought you were talking about Mk1 :shock: ....cheers
1965 Morris 850
1977 Leyland LS
PostPosted: Thu Sep 11, 2008 9:46 pm
Should have the repro heal mats in about three weeks.
I am confident they will be very good copies of the original, excluding the small wear area.
PostPosted: Fri Sep 12, 2008 5:51 pm
Who do you get to make the heel mats? Could they make a boot mat for a Morris 1100?
PostPosted: Fri Sep 12, 2008 9:49 pm
Yep I'm in to let us know when and how much.
PostPosted: Sat Sep 13, 2008 10:46 am
I'm with Morris 1100....
...the mat that I have is starting to disintigrate.....(mind is much better than none at all......thanks Kevan)
1969 Morris 1100 S Automatic
ahhhh......the interior smell of an old British car....
PostPosted: Sat Sep 13, 2008 9:54 pm
This photo shows the mat from my May 1970 MK II Cooper S when I first took delivery of the car. I believe this to be the original mat. :?:
Blue MK II
PostPosted: Sun Sep 14, 2008 10:00 pm
Never seen a Mk2 with that style heal mat, but your carpet looks original - strange things did happen with the Mk2's to use up stock.
PostPosted: Sun Sep 21, 2008 10:14 pm
The two 1969 Cooper S featured in Issue 14 of The Mini Experience had different heel mats (p 60).
Len Nations (chassis 1237) has the Mk1 mat, while Gavin Rolfe's (chassis 1119) has the Mk2 mat - and both are original.
Just goes to show the variation with the change-over period.
Watto. :shock:
PostPosted: Mon Sep 22, 2008 12:28 am
keep me updated. i'm intersted for my clubman
