Mark 2 Cooper S Register now live on Ausmini https://ausmini.com/forums/viewtopic.php?f=2&t=91011 |
Page 1 of 2 |
Author: | winabbey [ Fri Nov 13, 2015 5:09 pm ] |
Post subject: | Mark 2 Cooper S Register now live on Ausmini |
The Australian Mark 2 Cooper S Register is now live, and the Mark 1 Register was updated today. Navigate to Board Index > Mini Registers > Australian Mk 2 Cooper S Register. ... or click this link viewtopic.php?f=46&t=90887 The Register for the Clubman GT will be added in the next month or so as time permits. Feel free to provide comment and feedback in this thread. Hopefully additional vehicle data will be forthcoming, including from those who declined to provide it previously on the basis the register was seen to be in private hands and not viewable. Now it is out there in the public arena for the benefit of all Mini enthusiasts. Enjoy. ![]() |
Author: | Mick [ Fri Nov 13, 2015 5:32 pm ] |
Post subject: | Re: Mark 2 Cooper S Register now live on Ausmini |
Well done! |
Author: | gtogreen1969 [ Fri Nov 13, 2015 5:47 pm ] |
Nice work. Just a couple of things that may need looking at. The M2 06 code was actually changed to 2/06 and was located at either the drip channel or behind the master cylinders on the bulkhead. Location of identifiers on the Australian Mark 2 Cooper S body: • Car Type (YG2S4) and Car Number (sequential commencing at 501) stamped into the top of the radiator shroud. • Body number prefix 2/06 followed by Body Number (sequential commencing at 001) initally stamped into the drip channel above the wiper motor then behind the master cylinders on the firewall bulkhead. For internal use only during manufacture so may not be easily visible. • From January 1970 an ADR (Australian Design Rules) Compliance Plate fixed to the vertical face of the crossmember behind the power brake booster. Two styles of plate were used - initially square plates secured with four rivets, then rectangular plates secured with two rivets (see photos below). Note: Unlike the Mark 1 Cooper S, no ID plate was used during Mark 2 Cooper S production. |
Author: | fordboat [ Fri Nov 13, 2015 6:00 pm ] |
Great work, I was pleased to see mine on there all details were right. |
Author: | winabbey [ Fri Nov 13, 2015 6:03 pm ] |
gtogreen1969 wrote: Nice work. Just a couple of things that may need looking at. The M2 06 code was actually changed to 2/06 and was located at either the drip channel or behind the master cylinders on the bulkhead. Thanks. Narrative updated. Was M2 06 used on any Mark 2's? fordboat wrote: Great work, I was pleased to see mine on there all details were right. Mine too, so that makes three car's ID's confirmed. ![]() |
Author: | Morris 1100 [ Fri Nov 13, 2015 6:35 pm ] |
Good stuff! |
Author: | gtogreen1969 [ Fri Nov 13, 2015 7:22 pm ] |
winabbey wrote: gtogreen1969 wrote: Nice work. Just a couple of things that may need looking at. The M2 06 code was actually changed to 2/06 and was located at either the drip channel or behind the master cylinders on the bulkhead. Thanks. Narrative updated. Was M2 06 used on any Mark 2's? I have info of a dozen or so stampings and they are all 2/06. The stampings were first located in the drain channel then around 5/1970 they went to behind the master cylinders usually under the colour stickers. I can't pinpoint the exact date as my last gutter stamping is 4/1970 and then firewall stampings start at 6/1970 |
Author: | gtogreen1969 [ Fri Nov 13, 2015 8:08 pm ] |
Doug I have just emailed you another 60 cars that are not on your list. Some of the info is incomplete but you should be able to get something to add to the register. |
Author: | MikeJ [ Fri Nov 13, 2015 8:42 pm ] |
Thanks to everyone for the effort put in so far. Hopefully more to follow. Good to see my last minute info made the list Doug. More on that to follow. |
Author: | winabbey [ Sun Nov 15, 2015 12:10 pm ] |
gtogreen1969 wrote: The stampings were first located in the drain channel then around 5/1970 they went to behind the master cylinders usually under the colour stickers. I can't pinpoint the exact date as my last gutter stamping is 4/1970 and then firewall stampings start at 6/1970 Interestingly, my (old) Sept 1970 MK II S had numbers stamped in the gutter. I had to remove the paint to see them but they were definitely there. I don't know if they were stamped on the firewall as well. I'll check my current Sept car when bodywork repairs are underway. |
Author: | winabbey [ Sun Nov 15, 2015 12:12 pm ] |
Following input from several knowledgeable people the description and location of identifiers section has been updated. |
Author: | Flute [ Sun Nov 15, 2015 3:09 pm ] |
Hmm, got me thinking, maybe there was a change over in the stamping codes prior to the MK2 because my late MK1 doesn't seem to have an M on the radiator shroud, just the 2 above 06. I thought maybe a bad stamping angle caused this but could it be they stopped using the M earlier? ![]() |
Author: | Flute [ Sun Nov 15, 2015 5:38 pm ] |
Excellent photos, thanks for uploading, shows my stamping bloke must have had the stamp on an angle so it didn't imprint the metal. Also rules out my theory so good to know. Cheers. |
