https://ausmini.com/forums/
Over sized Sump Plug
https://ausmini.com/forums/viewtopic.php?f=2&t=91005
Author:  GundyGuy [ Thu Nov 12, 2015 3:40 pm ]
Post subject:  Over sized Sump Plug
Can anyone tell me where i can buy an oversized sump plug for a cooper s
What size is the standard thread?
Author:  drmini in aust [ Thu Nov 12, 2015 6:00 pm ]
Post subject:  Re: Over sized Sump Plug
Standard sump plug thread is 5/8" UNC.
Most folks use a helicoil (or recoil) kit to restore the original size.
Recoil kit is good- by using a stepped tap, it uses the remains of the original thread to cut a new bigger one, aligned properly so there is less chance of the sump plug washer not sitting flat.
After cutting the thread and cleaning out, you wind a recoil/helicoil SS thread insert in and you're done.
Can do in situ, on car. Use a bottle of cheap oil to flush the swarf out before refilling.
Author:  bluewhitecoopers1968 [ Sun Nov 15, 2015 5:34 pm ]
Thanks Doc, I appreciate your response....
Author:  Convertible Mini [ Mon Nov 23, 2015 6:56 am ]
When taping the thread use plenty of grease on the tap to catch the swarf.
