It is currently Wed Aug 20, 2025 7:31 pm
 Post subject: Lay gear end float
PostPosted: Fri Nov 13, 2015 6:38 pm
Putting the GB back together and with the shims I have I get either:-
0.0025" or 0.008" end float on the lay gear.
The good book says 0.003 to 0.006
Is 0.0025" too tight. Just can't quite get 0.003 feeler gauge in :|
 Post subject: Re: Lay gear end float
PostPosted: Fri Nov 13, 2015 7:31 pm
.0025"will work. :)
If you want a little more, rub 1/2 a thou off the thrust washer on some 180 grit paper and a good flat (machined) surface or a piece of glass.
Measure washer thickness with a micrometer.
PostPosted: Fri Nov 13, 2015 7:51 pm
Thanks Kev
I was considering some wet and dry on glass.
As the 0.0025 slips in easily and the 0.003 just won't quite go, I'll assume it is close enough to 0.003"
Users browsing this forum: No registered users and 267 guests
