Wiring questions - Alternator and spare white wires https://ausmini.com/forums/viewtopic.php?f=2&t=91003 |
Author: | MiniVLT [ Thu Nov 12, 2015 2:00 am ] |
Post subject: | Re: Wiring questions - Alternator and spare white wires |
Aren't the white wires for the tacho? Goes to the coil? Cheers Shane |
Author: | drmini in aust [ Thu Nov 12, 2015 6:08 am ] |
Early cars with alternator like my Matic only had 1 brown wire from the alternator to the battery stud. I'm currently running a Clubby alternator, with 1 wire and the other spade is spare. Adding a 2nd wire will send 1/2 the current output through each. |
Author: | gtogreen1969 [ Thu Nov 12, 2015 7:53 am ] |
I will leave the alternator alone - i think it is a replacement so the extra brown wire may have been connected to the original alternator. They could be tacho wires. My car had a 2 gauge cluster from new but now has a 3 guage cluster with tacho. Only thing is i already have a whit wire going to the coil and everything is already working. Doesn't really matter. I have put them back inside the loom where I found them. |
Author: | miniron [ Thu Nov 12, 2015 9:48 am ] |
There are 2 types of clubman tachos. Early cars had a current sensing tacho which needs the 2 white wires connected in series with the coil. Later cars had a voltage sensing tacho which only requires one wire connected to the distributor side of the coil. RonR |
Author: | gtogreen1969 [ Thu Nov 12, 2015 10:19 am ] |
miniron wrote: There are 2 types of clubman tachos. Early cars had a current sensing tacho which needs the 2 white wires connected in series with the coil. Later cars had a voltage sensing tacho which only requires one wire connected to the distributor side of the coil. RonR Hi Ron My car has the current sensing tacho. I have peeled back the wiring loom a bit more and found 3 white wires from the cabin. 2 are the ones going nowhere. The third one is going to my coil. Its all taped back up now so on to the next job. |
Author: | Mick [ Thu Nov 12, 2015 4:50 pm ] |
The extra brown wires are a bit of a curiosity of the time. When pushing full charge current down the relatively thin charge wire (relative to the current it is pushing out) the alternator would measure a higher voltage at the back of the alternator than at the solenoid post. Its Voltage Triangle stuff actually. 12V(Batt) + 40Amp x 0.05 = 14 volts. The figures here are inaccurate, but the maths demonstrate the problem for the regulator. So there was a second brown voltage sense wire for the purpose of the regulator to allow it to measure the actual battery voltage rather than the artificially high voltage at the back of the alternator. Many alternators got rid of this extra requirement, but the wire often remains. |
