Show us ya fuel pump setup!! https://ausmini.com/forums/viewtopic.php?f=2&t=90970 |
Page 1 of 2 |
Author: | Budgiedagreat [ Fri Nov 06, 2015 6:00 am ] |
Post subject: | Show us ya fuel pump setup!! |
Hey guys Need some inspiration and ideas where to install my fuel pump, show me some picks.. Thanks |
Author: | simon k [ Fri Nov 06, 2015 10:07 am ] |
Post subject: | Re: Show us ya fuel pump setup!! |
standard place for electric fuel pumps is inside the rear subframe... right under the fuel tank |
Author: | JimL [ Fri Nov 06, 2015 10:40 am ] |
Author: | andrew9 [ Fri Nov 06, 2015 12:53 pm ] |
People often rubber mount those solid state pumps, they can be noisy. S/U pump in standard clamp, on standard bracket, it a bit of rubber inside the clamp. The cheapest fuel filter at the time just happend to be "Cooper" I like this pump, it makes a few soft ticks when the key is turned, before starting. lets me know it's working, that I have fuel, and that the float valve is not stuck. ![]() |
Author: | JimL [ Fri Nov 06, 2015 1:34 pm ] |
I've got ~3mm rubber gasket between the pump and the subframe. like you said it ticks a bit on startup but cant hear it when the car is running. |
Author: | justfanginaround [ Fri Nov 06, 2015 2:28 pm ] |
I don't have a pic atm but I run a Facet solid state 4 psi pump mounted in the rear subframe. Mounted on an old mini lower engine mount to stop the ticking / vibration. |
Author: | Budgiedagreat [ Fri Nov 06, 2015 5:17 pm ] |
That's a good idea with the rubber gaskets, I think I'll go a Su fuel pump I'm not to fussed with the noise, just want something that's super reliable and maybe if I turbo my engine down the track. Thanks guys for the help!! |
Author: | Chux [ Fri Nov 06, 2015 10:03 pm ] |
Cotton reels for keeping it quiet ![]() |
Author: | JR0000 [ Fri Nov 06, 2015 11:52 pm ] |
Author: | drmini in aust [ Sat Nov 07, 2015 6:39 am ] |
I like the square Facet pumps they go forever. And no bloody points!!! Wiring shown was for testing. Mounted on a centre exhaust mount, the hole centres are the same. Just drill 1 hole in the centre web & fit a nyloc nut. ![]() |
Author: | niffty64 [ Sat Nov 07, 2015 6:53 am ] |
This is my Fuelflow ecco pump. it wasnt bolted in when pic taken ![]() |
Author: | Budgiedagreat [ Sat Nov 07, 2015 12:38 pm ] |
The facet pumps look neat! And they're a bit cheaper than the Su pumps anyone ever go braided lines? |
Author: | drmini in aust [ Sat Nov 07, 2015 2:22 pm ] |
I use good old American made fuel hose. Unleaded fuel doesn't harden it. There is hardly any pressure there so no need for PROPER braided hose and Earl's flare fittings. I'd sooner trust the yankee hose than the `braided' UK rubbish. |
Author: | Morris 1100 [ Sat Nov 07, 2015 4:14 pm ] |
Braided hose lasts just as long as normal hose except you can't see when it is about to fail. |
