It is currently Wed Aug 20, 2025 3:51 am
 Post subject: Lay gear end float
PostPosted: Fri Nov 13, 2015 6:38 pm
Putting the GB back together and with the shims I have I get either:-
0.0025" or 0.008" end float on the lay gear.
The good book says 0.003 to 0.006
Is 0.0025" too tight. Just can't quite get 0.003 feeler gauge in :|
 Post subject: Re: Lay gear end float
PostPosted: Fri Nov 13, 2015 7:31 pm
.0025"will work. :)
If you want a little more, rub 1/2 a thou off the thrust washer on some 180 grit paper and a good flat (machined) surface or a piece of glass.
Measure washer thickness with a micrometer.
PostPosted: Fri Nov 13, 2015 7:51 pm
Thanks Kev
I was considering some wet and dry on glass.
As the 0.0025 slips in easily and the 0.003 just won't quite go, I'll assume it is close enough to 0.003"
