https://ausmini.com/forums/
Welding in a new front passenger floor question
https://ausmini.com/forums/viewtopic.php?f=2&t=90888
Author:  68AUTO [ Mon Oct 26, 2015 12:02 pm ]
Post subject:  Welding in a new front passenger floor question
Hi everyone,
I am going to embark on replacing my front floors - the car looks like the Flinstones car right now.
I am interested in how I should tackle the welding.
My thoughts are:
Close to firewall I would do plug welds
Everywhere else I would tack and do butt joints.
I hope that my question makes sense. I just wasn't sure if when using the patch panel you would need to use plug welds anywhere else.
Author:  drmini in aust [ Mon Oct 26, 2015 1:11 pm ]
Post subject:  Re: Welding in a new front passenger floor question
I wouldn't plug weld it. I would overlap it 10mm at front and seam weld it with MIG so it's weatherproof.
On top, and MIG underneath the lap too if it's on a spit.
Author:  68AUTO [ Mon Oct 26, 2015 4:46 pm ]
Out of curiosity, was that how they did it from factory or is that the way it should be done now?
From memory I had to remove the spot welds to separate the original rusted floor from the firewall.
Author:  Bubbacluby [ Mon Oct 26, 2015 4:49 pm ]
As you have described is the way I would do it.
Factory was just spot welds with a little bit of brazing here and there. And a touch of mig in a couple places )like where the floor pan joins the inner wheel arch just below the seatbelt strap door retainer). But put together with a spot welder.
They were then tarred over the top of the seams and then painted over the top
Author:  16sth [ Mon Oct 26, 2015 10:12 pm ]
Whether this is the right or wrong way to do it, that's exactly how I did mine, both sides.
Author:  bluewhitecoopers1968 [ Tue Oct 27, 2015 4:00 pm ]
Overlap and seam weld top and bottom. Mine also done this way 10 years ago and still perfect.
Author:  kevin [ Wed Nov 18, 2015 11:13 pm ]
68auto where did you get the floor repair panel from.
Author:  68AUTO [ Thu Nov 19, 2015 7:29 am ]
The image shown is just one that I found doing a quick Google search that would demonstrate what I was talking about.
The panel I got was probably from MiniSport (Aus). I needed an Aussie panel as the car I am working on is a Mini Matic.
Author:  drmini in aust [ Thu Nov 19, 2015 7:45 am ]
For cars `67 to `78 you need the Oz `hydro' panels. Also available from Karcraft, and Minikingdomonline.
