It is currently Wed Aug 13, 2025 1:29 am
PostPosted: Mon Oct 26, 2015 12:02 pm
Hi everyone,
I am going to embark on replacing my front floors - the car looks like the Flinstones car right now.
I am interested in how I should tackle the welding.
My thoughts are:
Close to firewall I would do plug welds
Everywhere else I would tack and do butt joints.
I hope that my question makes sense. I just wasn't sure if when using the patch panel you would need to use plug welds anywhere else.
1966 Morris Mini Minor Saloon (Dot) - 1275 Auto - Mongrel
1968 Morris Mini Van (Ivan) - 998 Auto - Mongrel
1968 Morris Mini.Matic (George) - Original
1968 Morris Mini.Matic (Charlie) - Original
PostPosted: Mon Oct 26, 2015 1:11 pm
I wouldn't plug weld it. I would overlap it 10mm at front and seam weld it with MIG so it's weatherproof.
On top, and MIG underneath the lap too if it's on a spit.
PostPosted: Mon Oct 26, 2015 4:46 pm
Out of curiosity, was that how they did it from factory or is that the way it should be done now?
From memory I had to remove the spot welds to separate the original rusted floor from the firewall.
PostPosted: Mon Oct 26, 2015 4:49 pm
As you have described is the way I would do it.
Factory was just spot welds with a little bit of brazing here and there. And a touch of mig in a couple places )like where the floor pan joins the inner wheel arch just below the seatbelt strap door retainer). But put together with a spot welder.
They were then tarred over the top of the seams and then painted over the top
PostPosted: Mon Oct 26, 2015 10:12 pm
Whether this is the right or wrong way to do it, that's exactly how I did mine, both sides.
PostPosted: Tue Oct 27, 2015 4:00 pm
Overlap and seam weld top and bottom. Mine also done this way 10 years ago and still perfect.
PostPosted: Wed Nov 18, 2015 11:13 pm
68auto where did you get the floor repair panel from.
1978 leyland mini van. New to this, be nice, dont know anything.
PostPosted: Thu Nov 19, 2015 7:29 am
The image shown is just one that I found doing a quick Google search that would demonstrate what I was talking about.
The panel I got was probably from MiniSport (Aus). I needed an Aussie panel as the car I am working on is a Mini Matic.
PostPosted: Thu Nov 19, 2015 7:45 am
For cars `67 to `78 you need the Oz `hydro' panels. Also available from Karcraft, and Minikingdomonline.
Users browsing this forum: No registered users and 274 guests
