It is currently Tue Jul 29, 2025 9:32 pm
 Post subject: knuckle joints
PostPosted: Sun Mar 13, 2016 9:21 am
Well i have reconditioned my front upper control arm
I brazed up the worn end thrust section and milled it back
Its perfect now
The problem now is the Knuckle Joint
When i went to fit the cup it just fell in the hole and was loose as a goose
the old one had to be dug out with a screw driver
So should it be a push in fit or loose?
The part number is RGSV1118 or 21A1163
1970 MK2 Cooper S
 Post subject: Re: knuckle joints
PostPosted: Sun Mar 13, 2016 8:20 pm
should be a push fit - it won't last long if it can flop around...
PostPosted: Mon Mar 14, 2016 5:38 pm
Went back to my local mini parts supplier and all his stock was wrong
His supplier has dodgy parts
Yellow packet with made in Taiwan
1970 MK2 Cooper S
PostPosted: Mon Mar 14, 2016 5:57 pm
I was at minisport last year and an upset customer came back in with a set of knuckle joints that were loose. There must be a few bad batches around.
PostPosted: Sun Mar 20, 2016 4:28 pm
Knuckle joint issue is Fixed
The Cup was the wrong OD but right ID
So they replaced the cup with a correct size one and Bob's Ya Aunty
1970 MK2 Cooper S
Users browsing this forum: Phil 850 and 118 guests
