https://ausmini.com/forums/
Alloy rocker cover
https://ausmini.com/forums/viewtopic.php?f=2&t=89995
Page 1 of 2
Author:  bluewhitecoopers1968 [ Sun Jul 19, 2015 3:43 pm ]
Post subject:  Alloy rocker cover
Does anyone have any information on this rocker cover, is it rare or anything? Cheers. Richard. Image
Author:  TK [ Sun Jul 19, 2015 4:45 pm ]
Post subject:  Re: Alloy rocker cover
nope not rare.
Author:  bluewhitecoopers1968 [ Sun Jul 19, 2015 5:24 pm ]
TK wrote:
nope not rare.
Thanks bud.
Author:  drmini in aust [ Sun Jul 19, 2015 8:33 pm ]
They were sand cast, Australian made, most have no maker's name, but the one on Laingy's 1387 Mini van does .
I had one on my 1412 stroker.
They are quite a solid casting, unlike the flimsy diecast Chinese ones being sold now.
Author:  bluewhitecoopers1968 [ Tue Jul 21, 2015 12:00 pm ]
Thanks doc, no makers name on mine. My 1.5 roller tip rockers fit under so I'll be sporting a new cover.
Author:  Cooper_Matrikon [ Tue Jul 21, 2015 7:11 pm ]
I've gone back to an original tin one as the alloy one I had on was fouling on the rockers. I think it was because the grommets were a bit flogged though. I might pull it out and grab a new set.
Author:  drmini in aust [ Tue Jul 21, 2015 7:35 pm ]
Evan,
Sometimes you need to move rocker covers back a bit to clear hi-lift rockers. Particularly if you are running my Corolla ones still.
I don't use the rubber grommets now, the crap rubber they are made from is allergic to oil. I cut polyurethane washers and fitted them instead.
Author:  Cooper_Matrikon [ Thu Jul 23, 2015 7:49 pm ]
Good idea Doc. I did note that they would clear by moving the cover back slightly but my grommets were already prerty shat. Time to revisit.
Author:  drmini in aust [ Fri Jul 24, 2015 6:52 pm ]
With that alloy cover you don't need a grommet through the hole.
I can make you a couple of 5mm thick poly washers, but not until after 1st August. My mate has my bit of poly sheet, and he's on hols.
Author:  bluewhitecoopers1968 [ Fri Jul 24, 2015 7:59 pm ]
Just get some new grommets from Lincoln and slice off the bit that goes through the hole. Tighten down the cover a little and push it back. Finally tightly finish it off white holding it back.
This should then give an extra 3 or so millimetres clearance. Done. xxx
Author:  timmy201 [ Tue Sep 06, 2016 9:03 pm ]
Bit of a thread dig... any idea on the maker?
Author:  awdmoke [ Tue Sep 06, 2016 10:51 pm ]
Nope. I have an unmarked one too, although I could get my 1,5 roller rockers to fit if I positioned it just right.
Author:  drmini in aust [ Wed Sep 07, 2016 6:32 am ]
Laingy's one has the name 'T J Dunn and Co, Sydney' cast on top.
Author:  RNY997 [ Wed Sep 07, 2016 12:39 pm ]
Lynx was who I thought might have had something to do with making the finned A-series and B-series ally covers here.
Castalloy in Adelaide and Monaro Motors in Melbourne were other makers but in the 1950s.
Author:  Curly [ Wed Sep 07, 2016 4:11 pm ]
I have the same alloy rocker cover (albeit somewhat modified) on my Bugeye Sprite motor. I always thought it to be a Lynx product, but there's no manufacturer's markings on it as far as I know.
