It is currently Mon Jul 28, 2025 1:44 pm
 Post subject: popped knuckle joints
PostPosted: Sat Jun 11, 2016 1:19 pm
Hi, Recently reinstalled the rear subframe and trailing arms and shockers etc and left car on rear wheels with a spit attached to the front. Moved it several times around shed and bounced on the shockers a few times. now i find the knuckle joints have popped out. what is supposed to stop this happening ie just the shocker. I used the old trumpet with new cones and knuckles and rebuilt trailing arms. Any suggestions or ideas. All help appreciated
Regards
Graeme
1978 Leyland Mini 1275 LS
Hi Ho Silver and hopefully away
PostPosted: Sat Jun 11, 2016 2:28 pm
The shock stops the trailing arm from dropping too far down and pulling out of the joint / rubber cone / trumpet etc
Roads need more corners
PostPosted: Sat Jun 11, 2016 3:50 pm
Isnt there long and short shocks?
PostPosted: Sat Jun 11, 2016 4:54 pm
Just had a better look and it seems the rubber dust seals have pulled off the cup rather than the ball pulled out
