It is currently Tue Jul 22, 2025 9:31 am
PostPosted: Fri May 13, 2016 6:17 am
Valvoline 20w 50 XLD Premium 4 litres for $10.
time to stock up
https://www.autobarn.com.au/valvoline-x ... 50-oa03628
PostPosted: Fri May 13, 2016 12:17 pm
Has anyone used this https://www.penriteoil.com.au/products. ... oducts=574 or the Miller's version?
Maelgwn No Mini Yet :(
PostPosted: Fri May 13, 2016 1:00 pm
Yes, I tried the Penrite Classic Mini oil for 3 consecutive changes. I always change my oil at 4,500 kms. And whilst I generally don't join "The Great Oil Debate", here is my experience...
With the Valvoline my car will cold start and idle at 72psi.
Once warm, it will idle at 50psi, and running at 3,000 RPM I will see 70psi.
This is very consistent, regardless of outside temperature, distance driven, or number of KMs since last oil change.
With the Penrite Classic Mini, the car will cold start and idle around 85psi.
Once warm, it idles around 43psi, and running at 3,000 RPM I will see 58psi.
After a good stint of freeway driving (45 minutes +), the car will idle at 35psi, and at 3,000 RPM I'll be lucky to get 50psi.
I can't comment on the protection or lubrication characteristics of either oil. However, I really dislike these huge swings in pressure and inconsistent operation of the Penrite oil, and will therefore never use it again (especially when the Valvoline can be had for $10).
(*All numbers +/- 3psi. Readings taken from a mechanical Smiths gauge.)
1998 Rover Mk VII
2001 Honda CBR 929RR (street)
2014 BMW S1000RR (track)
PostPosted: Fri May 13, 2016 4:10 pm
thanks for your insight :)
PostPosted: Fri May 13, 2016 4:23 pm
I run Gulf Western XP 20w50
It happily sat on GR's dyno at 75~psi
It will hold 65-75psi depending how hot it is when on the freeeway and i get about 35-40psi when idling.
http://www.flickr.com/by_dan
2014 Land Rover Defender 90
PostPosted: Fri May 13, 2016 4:37 pm
time to stock up
If stocking up for use in a Classic mini,
VALVOLINE XLD CLASSIC 20w-50 is the one to use.
The "Classic" has the ZINC required for the Flat Tappet cam in a classic Mini.
The "PREMIUM" is not the right choice for the Classic Mini.
Dave
PostPosted: Fri May 13, 2016 4:53 pm
time to stock up
They also have 1L for $12.99 :D
https://www.autobarn.com.au/valvoline-x ... 1l-1054-58
PostPosted: Fri May 13, 2016 5:56 pm
sitnlo62 wrote:
time to stock up
Dave
so have i got the wrong info. should i be using classic not premium?
PostPosted: Fri May 13, 2016 6:52 pm
I have tried the Premium and it made the engine rattle a bit and the oil pressure dropped. I dumped it out after 1 week.
PostPosted: Fri May 13, 2016 7:15 pm
This thread has some info on XLD Classic and XLD Premium:
viewtopic.php?f=2&t=86371&hilit=xld+classic&start=0
Cooper S Mk2
Cooper S Mk1
PostPosted: Fri May 13, 2016 8:23 pm
Thanks for that.
That's the thread i based my oil choice on.
As classic was being phased out and premium was as good if not better.
PostPosted: Fri May 13, 2016 9:02 pm
I tried the gulf western xp 20w50 last change and found it very good, very similar to the valvline xld classic. I got some of the cheap xld premium so it will be interesting to see if I find the same as GTOgreen1969.
The premium still has the zinc according to valvoline, see second page of thread quoted above. It's funny the classic took a long time to phase out.
PostPosted: Fri May 13, 2016 9:13 pm
Gulf Western 20w50 fixed my old Mazda rattly hydraulic lifters, especially when hot. Put it down to better oil pressure. It's made in Australia and got good results from GR so you can't get a better recommendation than that.
I'm spending a small fortune on my mini engine rebuild so it's Gulf Western for me, and it's not that much dearer anyway.
PostPosted: Fri May 13, 2016 9:30 pm
I think the issue was that my engine was a little tired and the Premium cleaned it out too much.
PostPosted: Tue May 17, 2016 11:19 am
So far the XLD premium is behaving similar to the old XLD Classic and Gulf western in my motor. It's a shame they are both only 4 litre.
Users browsing this forum: Bing [Bot], ken@miniauto and 92 guests
