https://ausmini.com/forums/
boot liner material
https://ausmini.com/forums/viewtopic.php?f=2&t=88645
Page 1 of 2
Author:  doogie [ Mon Feb 16, 2015 10:00 pm ]
Post subject:  boot liner material
Anyone know of a source for the thin Masonite for making a cooper s boot lid liner?
Doogie
Author:  Besser [ Mon Feb 16, 2015 11:26 pm ]
Post subject:  Re: boot liner material
Get a standard one from bunnies and take it to a cabinet maker they can profile it down with their cnc router
Author:  Firefirey [ Tue Feb 17, 2015 6:07 am ]
Doogie
Hi
I got the original Masonite ( if that is it's correct name ) from John Smidt Mini King NSW about two years ago for $30.00.
Brought it home and thinned it to the correct size, John can advise. I think it was 4mm and then made a jig to curve the board by bending slowly and using water. Once you get the curve you want, hold the board in place and let it dry out fully. I waited a week then remove from the jig and the board will hold that curve shape. It pays to screw the board to the boot lid as soon as you can. I painted the board after the curve process and drying.
Came out looking so original and I found some florentine bronze cup washers and screws which the factory used to screw the liner into place.
I put john onto the cup washer supplier as he had run out and was looking for a new supplier.
Hope this helps.
Regards
Author:  Mick [ Tue Feb 17, 2015 6:38 am ]
The material is Leatherwood Masonite.
http://i207.photobucket.com/albums/bb2/ ... erS124.jpg
Author:  Ian McNeil [ Tue Feb 17, 2015 9:16 am ]
Doogie
Hi Greg, I obtained 2.5 mm Trimboard masonite from a local upholstery supplier in Brisbane called Daley's Auto Marine & Upholstery Supplies at Acacia Ridge- 0737173900
They also supplied Trimboard embossed 1.5 and 2.5mm cardboard which is embossed with a pattern in gloss finish on one side and I believe the original boot boards were cardboard but not sure as I sold a very original board from a Mk1 to Mokesta on this forum some time ago. He may be able to confirm the original material. It would not be practical to buy a large sheet of this stuff in Brisbane and freight it to SA but they could possibly put you on to a supplier in Adelaide or you could search directory for local upholstery suppliers
Ian
Author:  drjbeam [ Tue Feb 17, 2015 12:09 pm ]
I could have had so much 4mm Masonite from the house next door when the people were ripping the walls out a few years ago
they used to use it like gyprock in the old days on the inside
Author:  low n blown [ Tue Feb 17, 2015 1:47 pm ]
Doogie,
The stuff John has is spot on, its just a little thick as stated but it is the right stuff. The replica stuff around is crap and don't use cardboard.
G.
Author:  winabbey [ Tue Feb 17, 2015 2:22 pm ]
low n blown wrote:
Doogie,
G.
John's sheets were acquired from the factory during one of their sell-offs so are absolutely authentic. He has had the lid profile and mounting holes laser cut to the original pattern. They just need thicknessing, as Greg says, and then painted black. The current finish is the standard masonite readycoat primer.
I chuckled at Firefirey's mention above of the screws and cup washers. John is adamant the Australian Cooper S boot lid board was fixed with Florentine Bronze screws/washers but all the parts books I've seen specify nickel plated components. I've only ever seen nickel in the flesh but John has vastly more practical experience than me. For now it's one of life's little mysteries. :|
Author:  Mick [ Tue Feb 17, 2015 4:00 pm ]
I've got a stack of the florentine bronze screws from John from some time ago. I'm not entirely sure, but I think he had them plated. Its quite a challenge to find the nicely domed cross head self tappers they used. The washers are easier.
Funnily enough, I've still got an large upright closet made of the leatherwood masonite. It was quite popular back in the day as a furniture material. I keep all my deepest secrets in that closet :shock:
Author:  winabbey [ Tue Feb 17, 2015 4:27 pm ]
To help the search, those screws are part number RTZ604, which equates to Recessed Raised Countersunk-Head Tapping Screws Type A, 6 gauge, 1/2" long, zinc plated.
Author:  Firefirey [ Tue Feb 17, 2015 7:59 pm ]
Cup washer FWP 106
Could there be a change point with YKG2S2 - 4 ?
Author:  miniron [ Thu Feb 19, 2015 9:07 am ]
Just checked mine owned from new, late 68 build car number 48xx.
Its all original but after 46 years its a little the worse for wear. Board is Masonite leatherwood?? embossed pattern and painted black.
Thickness is approx 3mm, perhaps a little less say 2.8mm but the ravages of time may have caused some shrinkage.
The original screws are zinc plated as mentioned above with nickel plated cup washers.
No florentine bronze anything in sight here.
IIRC??? the screws and cup washers are the same as those securing the rear edge of the door trims.
RonR
Author:  Anthony [ Tue Apr 03, 2018 10:55 pm ]
Did anyone find a local supplier of screws and cup washers that look similar or the same. Any photos??
Author:  Panthersteve [ Wed Apr 04, 2018 9:10 am ]
winabbey wrote:
low n blown wrote:
Doogie,
G.
John's sheets were acquired from the factory during one of their sell-offs so are absolutely authentic. |
Just wondering why John's sheet is too thick if it came from the factory and is absolutely authentic :?: :shock: :?
Steve
Author:  winabbey [ Wed Apr 04, 2018 9:32 am ]
Steve
Because it is the source material. BMC also needed to put them through a thicknesser before cutting to shape and drilling. :wink:
