It is currently Sun Jul 27, 2025 12:05 pm
Post new topic Reply to topic  [ 42 posts ]  Go to page 1, 2, 3  Next
PostPosted: Tue Oct 13, 2015 4:19 pm
I have a quality trickle charger (ctek) which I plan to keep connected to maintain battery health. I believe it does a very gentle maintenance cycle.
Is it safe to keep it connected with the boot closed. I usually connect via the engine bay.
It's just the nuisance factor of the boot always open.
PostPosted: Tue Oct 13, 2015 4:41 pm
Online
The manual online says the battery needs "proper ventilation" during charging. I guess if it was under the bonnet like a normal car that would be enough ventilation, but being stuck in a closed boot might be dangerous, as explosive gases could be emitted..
http://www.ctek.com/Archive/ProductManu ... 0.8_EN.pdf
PostPosted: Tue Oct 13, 2015 5:27 pm
Well your boot is closed when you drive along with the alternator charging it up, so thats point 1
Point 2 would be how well sealed is your boot.
I would suggest boot open is the best situation and surely you could create a small hook similar to the current stay cable that would keep the boot open just a little bit, allowing an open boot without it hanging down past the back of the car.
PostPosted: Tue Oct 13, 2015 5:45 pm
Yeah point 2 was what I was thinking. If I was charging a low battery I would definitely give it plenty of ventilation. I was more wondering about the very light "pulse" charge when the battery is virtually at 100%
PostPosted: Tue Oct 13, 2015 5:50 pm
The boot is not sealed from the body, so I just leave a window open. Mine is often on trickle charge for 3 or 4 days at a time.
PostPosted: Tue Oct 13, 2015 7:42 pm
Mine is on trickle charge for 3-4 Years at a time. Boot seals so badly the cable isn't even tight
PostPosted: Tue Oct 13, 2015 8:56 pm
Just to be safe than sorry, isn't it easy to just have the boot open a bit.
It would really be sad to blow the little bugger up !
PostPosted: Tue Oct 13, 2015 10:02 pm
I have and use a ctek charger in the boot I close the boot as much as possible with the cord not being able to shut all the way and have it charging for weeks/months with no problem at all. Don't forget the boot is not sealed totally you don't suffocate if locked in a boot !
PostPosted: Wed Oct 14, 2015 8:47 am
Sure would....one little spark in the boot area whilst you are not looking and it could end in tears...similarly, if the garage area is well sealed and air don't move in it...an explosive mix of built up gas and petrol fumes could occur.
PostPosted: Wed Oct 14, 2015 9:33 am
Interesting thought. My car can be in its Carcoon for years on end with the charger trickling away and the boot shut..
PostPosted: Wed Oct 14, 2015 9:47 am
Online
I agree, the chances of something going bad is extremely slim. There is also a difference between ventilation and having holes in a box. There would be some nominal amount of air volume changes over time to be considered "ventilated". Hydrogen is explosive at 4-75%, so something that could build up over time.
During battery charging, oxygen and hydrogen are released after a cell has achieved approximately 95 % of its charge, during boost charging or overcharging
http://www.safeenvironments.com.au/hydr ... ging-room/
Something to think about anyway... maybe just leave the boot cracked open a couple of cm?
PostPosted: Wed Oct 14, 2015 10:25 am
Most sponge boot seals leak at the bottom where the ends touch anyway.
PostPosted: Wed Oct 14, 2015 12:44 pm
Hydrogen is lighter than air, so will escape upwards.
PostPosted: Wed Oct 14, 2015 4:50 pm
Yep, most likely up the rear pillars into the roof lining where it will pool waiting for the interior light to set it off. :mrgreen:
I once blew up a truck battery when using an angle grinder about six foot away from it. They go pop when they go.
PostPosted: Wed Oct 14, 2015 9:01 pm
Kaboom :!: :shock: :lol:
