https://ausmini.com/forums/
clutch master cylinder removal
https://ausmini.com/forums/viewtopic.php?f=2&t=87696
Author:  AWOODY [ Sun Nov 09, 2014 4:11 pm ]
Post subject:  clutch master cylinder removal
Is there an easy way to remove the nut under the right side , it only took 15,000 tiny turns !!!
Author:  mickmini [ Sun Nov 09, 2014 4:46 pm ]
Post subject:  Re: clutch master cylinder removal
You can do it with a ratchet ring spanner, but you might need the right bend in one. Still lots of little movements, but you can at least leave the ring on the nut the whole time.
Author:  drjbeam [ Sun Nov 09, 2014 5:37 pm ]
Stubby spanners
Author:  goodie [ Sun Nov 09, 2014 7:44 pm ]
Short turns with an open ender , once you have cracked it that is .
Author:  drjbeam [ Sun Nov 09, 2014 8:21 pm ]
http://m.supercheapauto.com.au/Product/ ... ece/298131
Stubby spanners
Might get a set myself this week being Imperial and $22.88 for a set from $34.99
I have a aldi metric set i used when i done mine
Author:  goodie [ Mon Nov 10, 2014 6:50 am ]
Yep can't beat them , i bought 2 sets ( imp & metric ) el cheapo brand years ago off bloke at a swap meet in Cessnock , best thing i ever did for working on mini's .
Author:  Timbo [ Mon Nov 10, 2014 10:31 am ]
I have a purpose modified spanner for that job. I bought a cheap spanner, cut the shaft down short and ground the back of the head down smaller to give it some more clearance.
I have a few specially modified tools like that. I only use ones that are bought for the purpose of modifying though.
Author:  AWOODY [ Mon Nov 10, 2014 4:06 pm ]
Thanks for the replies.
