It is currently Thu Aug 07, 2025 8:12 am
PostPosted: Sun Nov 09, 2014 4:11 pm
Is there an easy way to remove the nut under the right side , it only took 15,000 tiny turns !!!
PostPosted: Sun Nov 09, 2014 4:46 pm
You can do it with a ratchet ring spanner, but you might need the right bend in one. Still lots of little movements, but you can at least leave the ring on the nut the whole time.
PostPosted: Sun Nov 09, 2014 5:37 pm
Stubby spanners
PostPosted: Sun Nov 09, 2014 7:44 pm
Short turns with an open ender , once you have cracked it that is .
PostPosted: Sun Nov 09, 2014 8:21 pm
http://m.supercheapauto.com.au/Product/ ... ece/298131
Stubby spanners
Might get a set myself this week being Imperial and $22.88 for a set from $34.99
I have a aldi metric set i used when i done mine
PostPosted: Mon Nov 10, 2014 6:50 am
Yep can't beat them , i bought 2 sets ( imp & metric ) el cheapo brand years ago off bloke at a swap meet in Cessnock , best thing i ever did for working on mini's .
PostPosted: Mon Nov 10, 2014 10:31 am
I have a purpose modified spanner for that job. I bought a cheap spanner, cut the shaft down short and ground the back of the head down smaller to give it some more clearance.
I have a few specially modified tools like that. I only use ones that are bought for the purpose of modifying though.
1955 BSA C11G
1961 Morris Mini Traveller
1969 Triumph TR6R
1977 Leyland Moke Californian
PostPosted: Mon Nov 10, 2014 4:06 pm
Thanks for the replies.
Users browsing this forum: Bing [Bot] and 93 guests
