It is currently Sat Aug 02, 2025 8:18 pm
PostPosted: Sat Nov 08, 2014 12:29 pm
Today I made and used a puller to remove these pesky needle bearings.
For details see in the how-to forum,
viewtopic.php?f=25&t=87679
PostPosted: Sat Nov 08, 2014 12:35 pm
Have you thought of going into production Kev? You make some really handy stuff.
PostPosted: Sat Nov 08, 2014 12:46 pm
Mate, I'm now retired, but I share this info so other folks don't run out of expletives getting these mothers out. :lol:
I think it was quicker to make this tool than it was to butcher the last 2 bearings out.
Another point I'll make here is IF you find original STEEL grease tubes still in there, KEEP EM!! As the plastic ones you get with the repair kits are all cr@p.
PostPosted: Sat Nov 08, 2014 3:46 pm
I just slip a steel rod through from the opposite side then weld the end to the bearing cage and then hammer it out from the other side (like a drift/punch).
PostPosted: Sat Nov 08, 2014 10:01 pm
I used to MIG weld a bolt in there and pull it out, but the tool is much quicker.
They don't weld real good with the grease in the bearing either.
PostPosted: Sat Nov 08, 2014 10:22 pm
Yeah it wasn't the easy option but it works.
PostPosted: Sun Nov 09, 2014 9:06 am
just saw the docs how to... another good tool
the measurements made me wonder whether the standard lifter could be used as the bar stock.... plenty around
(i think .8120 diameter rings the bell)
PostPosted: Sun Nov 09, 2014 9:33 am
Will put that on the to do list. Thanks Doc
(Turn the flange to 0.805" diameter) thats 20.45mm for us young ones!:)
1963 Morris 850 Smoke Grey
1963 Morris 850 Shadow Blue
1965 Morris Mini Smooth Van
1966 Morris Mini Van
1969 Morris Mini Deluxe Resto
5/72 Clubman Gt
PostPosted: Sun Nov 09, 2014 9:43 am
Nope the lifter is brittle cast iron, and is chill cast (hardened) on the face. No way you will drill it, and it's too big inside anyway.
Just buy an offcut of high tensile steel bar. It's cheap.
PostPosted: Sun Nov 09, 2014 10:44 am
The Mini King
Excellent As usual Doc,
In my younger days I used a Loxin tightened it up, then punched or pressed it out
Users browsing this forum: Bing [Bot], s-c1293 and 89 guests
