https://ausmini.com/forums/
Blow through Eaton M45 - new manifold
https://ausmini.com/forums/viewtopic.php?f=2&t=87626
Author:  michaelb [ Sun Nov 02, 2014 2:01 pm ]
Post subject:  Blow through Eaton M45 - new manifold
Hi guys,
Do you think this will work?
http://www.podifold.com
It does look like it will avoid the current issues with the suck through kits.
I'm very tempted
Author:  mickmini [ Sun Nov 02, 2014 2:21 pm ]
Post subject:  Re: Blow through Eaton M45 - new manifold
Blow through carbs have their own set of problems.
But this type of set up allows intercooling and does not have fuel in the rotors, two big benefits.
Ultimately you would want to use this with a SPI set up to avoid having to stuff around with a pressurised carb or go whole hog and have twin injectors.
Go for it i say.
michael
Author:  norm74 [ Sun Nov 02, 2014 2:46 pm ]
looks like a great idea, if you convert the price with the fitting kit it works out to $1035 for a bare manifold and fitting kit :shock:
then you have to buy supercharger, turbo plenum, turbo HIF44 as they are sealed.
tensioner kit for the belt, it would add up pretty quick.
dont knock me i like the idea it looks great but for $998 for a bare manifold its a bit dear.
would stop alot of the problems that the other kits have, also you could run more boost because you can run an intercooler.
Author:  Babes [ Sun Nov 02, 2014 3:57 pm ]
Had I of not already embarked on my latest effort I would grab one of these in a heartbeat.
Author:  Minimadmarty [ Sun Nov 02, 2014 5:58 pm ]
I like the blow through concept it makes sense. Go of it I say, done forget to run a build thread on here :D
Author:  michaelb [ Sun Nov 02, 2014 6:25 pm ]
May be a while, but you never know... :wink:
Author:  wallie [ Mon Nov 03, 2014 9:27 am ]
i saw something similar too these on the weekend fitted too a car looked pretty good, wasn't running an intercooler but still looked pretty cool having the carby sitting down behind the grille getting more cool air
Author:  michaelb [ Mon Nov 03, 2014 3:47 pm ]
Or could have been like this?
Author:  wallie [ Wed Nov 05, 2014 12:16 am ]
that would be the 1
