It is currently Tue Jul 22, 2025 10:34 pm
 Post subject: HID headlight kit
PostPosted: Mon Oct 20, 2014 10:59 am
Whilst these would make it nice for driving, how annoying would they be for other drivers? http://www.ebay.com.au/itm/Leyland-Mini-Cooper-S-Moke-Morris-Minor-Jaguar-Austin-55W-HID-Hi-Lo-Headlights-/281101974245?pt=AU_Car_Parts_Accessories&hash=item4172fbbae5
Mind you there is no mention of whether the mod is legal or not in the ad, yes I know the earlier cars are not required to meet the ADR which HID lights come under but I am guessing if you add them you would then have to comply
 Post subject: Re: HID headlight kit
PostPosted: Mon Oct 20, 2014 11:07 am
Ofcourse the ad ad wouldnt mention if the mod was legal or not: it probably isnt!
:D
PostPosted: Mon Oct 20, 2014 11:43 am
Not legal at all.
PostPosted: Mon Oct 20, 2014 12:05 pm
Meh- just put a pair of Cibie Oscars on the front then. :)
PostPosted: Mon Oct 20, 2014 3:26 pm
the headlights dont look like there designed for HID's they look like a standard projector which are about as good as HID's in a standard halogen headlight.
being in SA these guys can hook you up with a better headlight that would suit a HID bulb a bit better http://www.superauto.net.au
HID's are very much illegal in aus & that kit particular being 6000k will be even more noticeable as its very blue tinge light
if your going HID's id stick between 4300k & 5000k just so its not as blue, 5000k is about the same as the brightest blue tinge halogens you can buy.
another alternative is LED headlights, CREE make 1's suitable for headlights as thats what alot of Euro's are coming out with even the 2014 BMW mini has a led headlight option, they will out live HID's and Halogens combined, & run a lot cooler, but like HID's aftermarket install's are not ADR
https://www.youtube.com/watch?v=6cLw1z-p8bA
PostPosted: Fri Oct 24, 2014 10:07 pm
Rover Cooper
HID's have to be self levelling and self cleaning here in Vic, so unless the car comes with them, dont even think about it, total waste of money and time, believe it or not, :-[
PostPosted: Sun Oct 26, 2014 8:15 am
HID are legal IF you fit the self adjusting and cleaning bits as well
For example Suzuki Swift Sport 05 to 2010 in Japan had HID as an option so factory made kit with all the bits necessary are available to fit HID to a Aussie Swift Sport 05 to 2010 provide you fit all the bits for self levelling and cleaning
for most that would go into the too hard basket and just changing headlights alone would be illegal
PostPosted: Sun Oct 26, 2014 4:45 pm
Just get the Halogen conversion kit from any of the mini shops that stock it. I seem to recall that mine cost around $90 from Pommie-land a few years ago. Money well spent, & legal if you get the lights with the correct diffusers on the front of the lens that keep light away from the RHS of the road.
Bolts straight in with no mods, apart from having to wire up the plug with three wires at the back of the headlight.
I hate illegal HID conversions. If a car is coming towards me with very bright lights that are blinding me, I give them a short blast with high beam. No response = High beam. Illegal HIDs have almost no difference between high beam or low, so if they "leave them on high beam", then so do I. (Assuming no other traffic in the area of course)
1.8L Sunshine - Legal, legit & lovinit
PostPosted: Mon Oct 27, 2014 11:14 am
Guess you can get the self levelling bit pretty easy, not sure what you need to do for the cleaning bit though?
http://www.ebay.com.au/itm/CLASSIC-MINI-WIPAC-RHD-HEADLAMP-SELF-LEVEL-TYPE-COOPER-AUSTIN-ROVER-MORRIS-/390368454536?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item5ae3c5e788
PostPosted: Mon Oct 27, 2014 2:56 pm
Would additional washer hoses rerouted to the lights & a better pump not work?
Cheers Brad
During the day I work on English designed cars & on my own time I work on English designed cars....
PostPosted: Mon Oct 27, 2014 4:17 pm
womble99 wrote:
only problem is its a halogen reflector lens, altho it would kinda work you wouldnt get the headlight cut off so it would just splash light everywhere, i tried a set of HID's in 1 of my car, its great if you want street signs to reflect dazzlingly bright but not great for seeing in the distance without a focused projector lens
this is the difference.
https://www.youtube.com/watch?v=uUWZSqR1NzA
Users browsing this forum: cgo and 104 guests
