https://ausmini.com/forums/
Front Drum Hubs
https://ausmini.com/forums/viewtopic.php?f=2&t=87581
Author:  cd_design [ Sun Oct 26, 2014 9:41 am ]
Post subject:  Front Drum Hubs
Are both the hubs the same on the front? as in, if you strip the front drum down to the basic hub, can I use any on either side?
One of my hubs is worn on the inside, bearings are loose on the outside and really tight on the inside.
Think I'd rather replace it to be on the safe side.
Thanks for any help..
Author:  TheMiniMan [ Sun Oct 26, 2014 10:12 am ]
Post subject:  Re: Front Drum Hubs
no, they`re sided,, as in a left hub is a left hub & a right is a right
i have hundreds of them if you`re stuck
Matt
0407 135 656
(07)3399 99 99
Author:  cd_design [ Sun Oct 26, 2014 10:35 am ]
OK. How do I tell left from right? I'll check and let you know what I need. Thanks
Author:  cd_design [ Sun Oct 26, 2014 1:55 pm ]
Looking at before photos, it shows the grease nipples to the front with steering arm mount to the top. Looks like I need a drivers side hub
Author:  drjbeam [ Sun Oct 26, 2014 6:24 pm ]
Upper and lower Ball joint Grease nipples face the front on both sides
Mini kingdom online has about 100 nos drivers side ones but no passenger side ones nos
I needed a passenger side one the other week and john let me go through the nos ones all drivers side ones but
I think it was $40-$45 for a nos one
