It is currently Sat Jul 26, 2025 5:44 pm
 Post subject: Ignition Key
PostPosted: Mon Oct 20, 2014 10:41 am
Hi All,
I picked up a steering column for one of my projects, but it didn't come with a key.
Where there many different keys? could I just try to find someone with some spares and get lucky? or can i get a new one cut by a lock smith?
or is none of that possible/worth the effort?
Thanks
1975 Hairy Lime/White Clubby
 Post subject: Re: Ignition Key
PostPosted: Mon Oct 20, 2014 3:57 pm
I would take the barrel to a locksmith, wont be expensive
It's easy once you know how.
PostPosted: Mon Oct 20, 2014 4:53 pm
There's a number usually stamped into the barrel which can be converted into a key type. Mini mobs used to have keyboards you could choose your pre-made key from. I think there must have been upwards of 50 on the board at a guess.
But other than that, a locksmith can create one by looking at the barrel with his locksmith thingos and cut a key to match.
PostPosted: Mon Oct 20, 2014 6:04 pm
Apparently not on the Clubman barrels I was told by someone who should know. Haven't confirmed myself though.
I agree, take it to a good locksmith. With the lock not installed in the car you won't have the added expense of a call out fee.
PostPosted: Wed Oct 22, 2014 8:59 pm
Ask shorty68 over on the moke forum http://www.mokeforum.com.au/index.php/t ... #msg119441
Hes a locksmith and has done work for john at mini kingdom online in the past
PostPosted: Sun Oct 26, 2014 11:27 am
I just checked my old one that i pulled apart and theres no key number on the barrel but the original keys came with a number punched on them
Users browsing this forum: mincs1 and 90 guests
