https://ausmini.com/forums/
Tie rod end rubber boots.
https://ausmini.com/forums/viewtopic.php?f=2&t=87341
Author:  ykg2s4 [ Mon Sep 29, 2014 1:10 pm ]
Post subject:  Tie rod end rubber boots.
hi,
Is anyone else finding the quality of the tie rod end ball joint rubber boots a bit lacking these days?
Once upon a time ago they used to out last or be on par with the useful life of rod end itself, but these
days seem to deteriorate with in a year or so. Is there anywhere you can buy just the boots? I've tried
a couple of mini store online catalogues but can't find them listed on their own. Does anyone now of a
place that sells them in OZ?
thanks
Author:  drmini in aust [ Mon Sep 29, 2014 1:22 pm ]
Post subject:  Re: Tie rod end rubber boots.
They are still listed by Karcraft.
p/no 17H3481/2
Author:  ykg2s4 [ Mon Sep 29, 2014 4:23 pm ]
Thanks doc. :)
Author:  boomini [ Tue Sep 30, 2014 11:43 pm ]
http://m.ebay.com.au/itm?itemId=280497984907
Found this. ..
Author:  timmy201 [ Wed Oct 01, 2014 2:24 pm ]
At Karcraft they are $2.15 each..
Author:  bluewhitecoopers1968 [ Wed Oct 01, 2014 2:32 pm ]
Plus postage :)
Author:  diecast [ Fri Nov 07, 2014 6:56 am ]
Yep I agree with ykg2s4's initial post.
My Tie rod ends are less than 2 years old, car has done <1000k's since then, and both boots completely perished. Purchased from a well known UK supplier. Will have to grab some boots from Karcraft.
Author:  peterb [ Fri Nov 07, 2014 7:07 am ]
Just an idea I've used before, the dust boots off wheel cylinders fit and are usually good quality rubber type material.
