It is currently Thu Aug 21, 2025 8:24 pm
 Post subject: choke cable
PostPosted: Mon Sep 15, 2014 6:06 pm
Hi all
I need a bit of advice here please. The mini has been harder to start lately and I have noticed that the choke is doing little more than operate the rev cam. It does nothing to make the main jet go down.
The car has twin SU's but only one cable for the choke. My question is should it have two cables and if only one what adjustments do I need to make. Thanks
 Post subject: Re: choke cable
PostPosted: Mon Sep 15, 2014 7:38 pm
It only needs one cable which it transmits to the passenger side carb. This carb then transmits through the linkage to the drivers side carb.
Is that linkage across rotating?
PostPosted: Mon Sep 15, 2014 7:53 pm
The Cooper and Cooper S have the cross shaft to run both chokes.
The BMC hot-up accessory kits only hooked the choke to one carby.
PostPosted: Mon Sep 15, 2014 8:23 pm
Does it begin to move as soon as you pull the choke out, or can you pull the choke out some way before the revs start to rise? The cable might have too much slack in it.
PostPosted: Mon Sep 15, 2014 9:28 pm
can you move the jet yourself by hand up and down freely?
I had a similar problem and it was that the jet adjusting that it slipped into was slightly bent!
1968 Mini-Matic
PostPosted: Mon Sep 15, 2014 10:24 pm
Thank you all for replying. I will do as you have suggested and have another go tomorrow, Thanks again
PostPosted: Tue Sep 16, 2014 7:36 am
Jet could be stiff or jammed. Might be worth removing the carb that has the choke and have a good look at the whole mechanism. The normal movement would be...
1st half of choke = idle up only
2nd half of choke = more idle up + jet drop
As Morris 1100 said if it's a aftermarket twin carb setup then it's normal for only one carb to run the choke to help with cold starts ....so it's important it works.
PostPosted: Tue Sep 16, 2014 8:10 am
A smear of grease on the cable and linkage works wonders too. :)
Users browsing this forum: Sahig131 and 306 guests
