How do these go together https://ausmini.com/forums/viewtopic.php?f=2&t=87165 |
Author: | Wombat [ Fri Sep 12, 2014 5:00 am ] |
Post subject: | How do these go together |
Picked up a pair of these while overseas. http://www.minispares.com/product/Classic/Drivetrain/CV%20Joints/GCV1102.aspx?0801&ReturnUrl=/search/classic/Pot%20joint.aspx%7CBack%20to%20search Does the drive shaft just push into the rubber boot - no external fastening? |
Author: | Irish Yobbo [ Fri Sep 12, 2014 10:10 am ] |
Post subject: | Re: How do these go together |
Yes, or at least that's how they are on my mini. The rubber boot folds around and sits on a flange on the drive shaft. If you pull on the drive shaft there is enough movement in the boot to allow it to extend out a few cm. Drive shaft: || ==||========(Outer CV) || Drive shaft with boot: ____ \ ||/ ==||========(Outer CV) ||\ ____/ Edit: The editor removes all spacing, so my horrible diagrams look even more horrible. |
Author: | drmini in aust [ Fri Sep 12, 2014 10:15 am ] |
Original boots had a clip around the rubber on the shaft IIRC, but these boots don't because they are already clipped to the pot joint.. |
Author: | Irish Yobbo [ Fri Sep 12, 2014 10:28 am ] |
drmini in aust wrote: Original boots had a clip around the rubber on the shaft IIRC, but these boots don't because they are already clipped to the pot joint.. Interesting - not really surprised as the mechanic working on my mini previously has done some interesting work. Mine were attached to the shaft, but the rubber was thick enough to grab on quite strongly without the clip. The mechanic obviously couldn't be bothered putting it on. |
Author: | drjbeam [ Fri Sep 12, 2014 6:31 pm ] |
Make sure the rubber aint rock hard on them like mine were from a supplier who gets there parts Or get new rubber boots from mini kingdom online |
