It is currently Mon Aug 11, 2025 1:29 am
 Post subject: Rear Floor Pan
PostPosted: Wed Sep 10, 2014 6:06 pm
Hi all,
Is there anywhere I can get the rear floor pan LH and RH from for an Australian Clubman? I can only find the UK ones that the pressing doesn't line up.
Any help would be much appreciated
Dave
 Post subject: Re: Rear Floor Pan
PostPosted: Wed Sep 10, 2014 7:49 pm
No one at this stage makes them best bet is to get one out of another car or try and get a sheety to make one
PostPosted: Wed Sep 10, 2014 9:16 pm
I used 2 front aussie pressings and performed a little cut and shut job. The only things, I had to remould the ends of the swages in the rear and shift the rear 2 of the mounting holes for the pipe cover plates.
Came out quite well if I do say so myself. :D :oops:
Current 1970 Mini K - full resto happening - finished and on the road since 10/2020 :)
2001 Falcon AUII XL 1 Tonne styleside ute
Mini History
1963 - 850 - wish I still had it
1965 - 850 - was an unfinished project, gone
1972 - Clubbie
PostPosted: Wed Sep 10, 2014 9:18 pm
I have a rear uk floor pressing but will attempt to section it lengthways to line up the flutes, then weld it all back together.
PostPosted: Wed Sep 10, 2014 10:09 pm
I would try Cooper S Imports in Victoria. From memory he had some on display at Watto's Grand Day Out.
They included the front and rear in one pressing.
PostPosted: Wed Sep 10, 2014 10:46 pm
Pm sent
Minis..
1976 van daily drive
1975 van
1968 deluxe in the shed
1967 deluxe high strung 1310
1959 austin healey sprite
