https://ausmini.com/forums/
Camshaft drive type
https://ausmini.com/forums/viewtopic.php?f=2&t=87125
Author:  bluewhitecoopers1968 [ Sun Sep 07, 2014 6:10 pm ]
Post subject:  Camshaft drive type
Hi all, this is my camshaft pictured below. Where can I get an oil pump to suit?
Cheers.
Author:  Mick [ Sun Sep 07, 2014 6:18 pm ]
Post subject:  Re: Camshaft drive type
Easy enough to get the pump (spider drive). You will also need the spider drive coupling which adapts the oil pump to the cam shaft.
This is the coupling:
http://www.minimania.com/images_temp/80 ... CHM108.JPG
To suit this pump:
http://www.minispares.com/image.axd?typ ... GLP141.jpg
Author:  bluewhitecoopers1968 [ Sun Sep 07, 2014 6:25 pm ]
I've seen the spider drive pumps but not the coupling.... Looking on the interweb I only found one on Minimania, are there any suppliers in Aus for the adapter? Thanks
Author:  Mick [ Sun Sep 07, 2014 6:27 pm ]
I had a look as well. I thought there would be a few more with these in stock.
The doc was making them a while back, but I reckon they would be common second hand.
Author:  bluewhitecoopers1968 [ Sun Sep 07, 2014 6:29 pm ]
Someone might have one in a bucket of bits and don't have a use for it :) :)
Author:  TheMiniMan [ Sun Sep 07, 2014 7:29 pm ]
i have a few of them
Matt
Bne
0407 135 656
(07) 3399 99 99
Author:  bluewhitecoopers1968 [ Sun Sep 07, 2014 7:36 pm ]
Matt
Bne
0407 135 656
(07) 3399 99 99
PM sent :)
Author:  drmini in aust [ Sun Sep 07, 2014 7:44 pm ]
I have the spider to slot drive ones new, these have a slot inside instead of a spline. Laser cut from 8mm steel plate.
They take the 1275A+ slot drive pump.
PM me if you want one, but Karcraft and TheMiniMan both stock them too.
Author:  John Smidt [ Sun Sep 07, 2014 10:05 pm ]
And Mini Kingdom Online
Author:  drmini in aust [ Mon Sep 08, 2014 8:38 am ]
Thanks John, I forgot you have them too. :oops:
re the original star ones with the spline inside, AFAIK they are NLA new everywhere now, except possibly from APT Fast in the states.
But I just searched their site and can no longer find them.
www.aptfast.com
Author:  TheMiniMan [ Mon Sep 08, 2014 3:29 pm ]
i have both the std spider drive piece & the good Docs adaptors in stock,,, which would you like
& yes i got your PM, but you just asked how much$?...
which one would you like?
Matt
Author:  bluewhitecoopers1968 [ Mon Sep 08, 2014 3:56 pm ]
Matt
I'll just call next time, not PM. Cheers
