Oil pressure gauge line off block issues https://ausmini.com/forums/viewtopic.php?f=2&t=87120 |
Author: | slacko [ Sun Sep 07, 2014 5:22 pm ] |
Post subject: | Re: Oil pressure gauge line off block issues |
Rotate the distributor 90 deg so the vac unit is on top and then move the plug leads back one post |
Author: | Mackie [ Sun Sep 07, 2014 5:31 pm ] |
How do you mean move back one post ? I'm pretty clued up for most things on the mini But never played with the distributor or timing so a bit nervous about moving it. Haha |
Author: | slacko [ Sun Sep 07, 2014 5:42 pm ] |
If you turn the out side of the dizzy 90 deg clock wise the the leads move back anti clock wise one out let on the dizzy cap . as in the same position as they where before , you will need to re time the engine after moving the dizzy |
