It is currently Tue Jul 29, 2025 10:37 pm
PostPosted: Sun Sep 07, 2014 5:08 pm
So I've done of serching and without buying a 90* angle fitting does anyone else know how I can install the oil gauge line without it hitting the distributor vac ?? I was hoping to use the T piece so can still have the dummy oil as a back up.
64' 850 1275cc
PostPosted: Sun Sep 07, 2014 5:22 pm
Rotate the distributor 90 deg so the vac unit is on top and then move the plug leads back one post
PostPosted: Sun Sep 07, 2014 5:31 pm
How do you mean move back one post ? I'm pretty clued up for most things on the mini
But never played with the distributor or timing so a bit nervous about moving it. Haha
64' 850 1275cc
PostPosted: Sun Sep 07, 2014 5:42 pm
If you turn the out side of the dizzy 90 deg clock wise the the leads move back anti clock wise one out let on the dizzy cap . as in the same position as they where before , you will need to re time the engine after moving the dizzy
