https://ausmini.com/forums/
replacing mini rear loom
https://ausmini.com/forums/viewtopic.php?f=2&t=87072
Author:  wolfmini [ Mon Sep 01, 2014 11:10 pm ]
Post subject:  replacing mini rear loom
Hi has anyone replaced the rear loom in there mini, the wiring goes through the a pillar.
my plan was to attach some scrap wire and pull it through and then use the scrap to pull through the new loom.
I can't get it to pull though, does anyone have any tips?
1988 mini mayfair
Author:  MINImal effort [ Tue Sep 02, 2014 10:14 am ]
Post subject:  Re: replacing mini rear loom
It's a pain....
I usually tape up the end of the loom so there are no loose ends. Try and keep as thin as possible.
A straightened out coat hanger is used as the pull through....
.... But even then a bit jiggling is often required.....
If anyone has a magic trick...I'm all ears.....
Author:  Timbo [ Tue Sep 02, 2014 1:46 pm ]
I just did the one in my Traveller, I pulled a piece of strong builder's string through when I took the old loom out then used it to pull the replacement one back again. The new loom was much more flexible than the 53 year old one I took out, so it went back in very easily.
